it works for me: https://media.exstasi.ovh/
sonarr has a redirect loop though. you should look trough its settings or remove proxy_redirect off;
from its config
from its config
#listen 80;
server_name media.exstasi.ovh;
access_log /var/log/nginx/media.exstasi.ovh.log;
#proxy_redirect off;
proxy_set_header Host $host;
proxy_pass http://localhost:8010/;
proxy_buffering off;
location /radarr {
proxy_pass http://localhost:7878/;
ssl_certificate /etc/letsencrypt/live/media.exstasi.ovh/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/media.exstasi.ovh/privkey.pem; # managed by Certbot
if ($host = media.exstasi.ovh) {
} # managed by Certbot
listen 80;
try
location /radarr/ {
proxy_pass http://localhost:7878//;
and if it doesn't work,
location = /radarr { rewrite ^ /radarr/ redirect; }
location /radarr {
rewrite /radarr/(.*) /$1 break;
(for the non-working ones.)
none worked
i came back to this
location /radarr {
# location = /radarr { rewrite ^ /radarr/ redirect; }
# location /radarr {
# rewrite /radarr/(.*) /$1 break;
# proxy_pass http://localhost:7878/;
# location /radarr/ {
# proxy_pass http://localhost:7878//;
if you login on the machine, does curl http://localhost:7878
produce any output?
nope nothing
I tried other apps like bazaar or sonarr, same result no output
on localhost? you need to start them, probably.
they are started for sure
good news
i tried this
location ^~ /radarr {
proxy_pass http://localhost:7878/radarr;
it worked
