404 or connection timeout after applying certbot to Django Nginx project
My domain is: www.briansia.com
I ran this command: sudo certbot --nginx
It produced this output: Successfully deployed certificate for briansia.com to /etc/nginx/sites-enabled/django_blog.conf
My web server is (include version):nginx 1.18
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Linode
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.30.0
I see your https site just fine. Do you still need help? If so, please explain more about the problem
What is the issue you are wishing to solve?
Sorry guys. It seems like the issue was resolved after changing the permissions of the IPv6 port through nginx.
