PS: May be you can't see that because you use your website from an internal ip address.
Chrome Version 44 - 2015-07-21
Firefox 51 was released on January 24, 2017
IE 8 - 19. März 2009
That's nothing to use.
@TheWojtek Does "SIGNUM Home Server" ring a bell? Could that also be the thing listening on port 80?
Now I see a redirect to the login and a new Letsencrypt certificate.
Looks like you have found that old blocking thing
@Osiris - you nailed it when you provided what can you actually see from the outside. While I take the blame for this (should have been checking from the outside world), it seems we have found a bug in Ubiquity USG firmware.
Now for the explanation:
Result: Certbot challenge performed flawlessly.
Ps: as I see in the --standalone logs, the logged inability to bind to port 80 on IPv4 is expected behavior.
Well, UPnP should not be able to hijack manual portmaps in the first place in my opinion! That's just terrible. IMO that's not on you, but on Ubiquity.
Luckily we found the issue! ![]()
That's true if you're already running something on port 80, yes. --standalone really is only for servers without any form of HTTP webserver, such as hosts only running a mail daemon.
@Osiris @JuergenAuer - thank you both for keeping me awake and for your input, wouldn't have fixed it without you both.
