404 Not Found Apache
My domain is: app.montor.site
1: montor.site
2: app.montor.site
3: www.app.montor.site
4: www.montor.site
blank to select all options shown (Enter 'c' to cancel): 2 3
Requesting a certificate for app.montor.site and www.app.montor.site
Domain: app.montor.site
Detail: Invalid response from http://app.montor.site/.well-known/acme-challenge/moHHK_-6hsZK5c-oooU0RxALF44XXRdthj64w7JFH-Y [92.53.124.174]: "\n\n404 Not Found\n\n
Not Found
\n<p"
Domain: www.app.montor.site
Detail: Invalid response from http://www.app.montor.site/.well-known/acme-challenge/dDiIAm59t9xijElLNEbBlPMMzTxHtENSDqB8Zmgi_gs [92.53.124.174]: "\n\n404 Not Found\n\n
Not Found
\n<p"
My web server is (include version): Apache 2.4.41
The operating system my web server runs on is (include version): Ubuntu 20.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.17.0
Also I found out that when i create verification file manually - site does not see it. Thanks in advance
Hi @stasvinokur, and welcome to the LE community forum :slight_smile:
Please show the output of:
sudo apachectl -S
Hi @rg305,
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 203465-ce29106.tmweb.ru. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443 montor.site (/etc/apache2/sites-enabled/montor.site-le-ssl.conf:2)
*:80 is a NameVirtualHost
default server app.montor.site (/etc/apache2/sites-enabled/app.montor.site.conf:1)
port 80 namevhost app.montor.site (/etc/apache2/sites-enabled/app.montor.site.conf:1)
alias www.app.montor.site
port 80 namevhost montor.site (/etc/apache2/sites-enabled/montor.site.conf:1)
alias www.montor.site
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Please show this file:
<VirtualHost *:80>
        ServerName app.montor.site
        ServerAlias www.app.montor.site
        DocumentRoot /var/www/app.montor.site
        ErrorLog /home/python/ParserSite/logs/error.log
        CustomLog /home/python/ParserSite/logs/access.log combined
        alias /static /home/python/ParserSite/web/parserWeb/static
        <Directory /home/python/ParserSite/web/parserWeb/static>
                Require all granted
        </Directory>
        <Directory /home/python/ParserSite/web/web/>
                <Files wsgi.py>
                        Require all granted
                </Files>
        </Directory>
        Alias /.well-known/acme-challenge/ /var/www/app.montor.site/.well-known/acme-challenge/
        <Directory "/var/www/app.montor.site/.well-known/acme-challenge">
                Options None
                AllowOverride None
                ForceType text/plain
                Require all granted
                RedirectMatch 404 "^(?!/\.well-known/acme-challenge/[\w-]{43}$)"
        </Directory>
        RewriteEngine Off
        #RewriteEngine On
        #RewriteCond %{HTTPS} off [OR]
        #RewriteCond %{HTTP_HOST} ^www\. [NC]
        #RewriteRule ^ https://montor.site%{REQUEST_URI} [L,NE,R=301]
        #WSGIDaemonProcess ParserSite python-path=/home/python/ParserSite/web python-home=/home/python/venv
        #WSGIProcessGroup ParserSite
        #WSGIScriptAlias / /home/python/ParserSite/web/web/wsgi.py
</VirtualHost>
Please try changing this:
                Options None
                AllowOverride None
                Require all granted
        </Directory>
To this:
  <Location /.well-known/acme-challenge/>
     DocumentRoot /var/www/app.montor.site/.well-known/acme-challenge
  </Location>
     Options None
     AllowOverride None
     Require all granted
  </Directory>
Thanks for reply! I tried to use it, but i get the following error
AH00526: Syntax error on line 32 of /etc/apache2/sites-enabled/app.montor.site.conf:
DocumentRoot not allowed in <Location> context
hmm...
Let's try reversing the logic:
[change the root and then redirect everything else]
  <Location "/.well-known/acme-challenge/">
    #do nothing special for challenges / ignore bad requests
  </Location>
  <Location "/">
    #redirect all other requests to HTTPS
    Redirect permanent "/" https://%{HOST}/$1
  </Location>
[order may matter so put these location sections near the bottom - if you want to handle the others in HTTP]
Apache config test is ok, but i get error validating data issue
1: montor.site
2: app.montor.site
4: www.montor.site
  Type:   connection
  Detail: Fetching http://app.montor.site/.well-known/acme-challenge/-e6VCm0PUvCNhtqCI9gKnCXNwUnooTkAWXlrntzvSSs: Error getting validation data
  Type:   connection
  Detail: Fetching http://www.app.montor.site/.well-known/acme-challenge/EjKIca1G5hh5uYfJh3G4b79ElwPps1mf5oAN9ukay_Q: Error getting validation data
Ok let's test the location.
echo "test file 1" > /var/www/app.montor.site/.well-known/acme-challenge/test-file-1234
mkdir /var/www/app.montor.site/.well-known/acme-challenge/.well-known
mkdir /var/www/app.montor.site/.well-known/acme-challenge/.well-known/acme-challenge
echo "test file 2" > /var/www/app.montor.site/.well-known/acme-challenge/.well-known/acme-challenge/test-file-4321
One of those two files should be accessible from the Internet via two of these requests:
http://app.montor.site/.well-known/acme-challenge/test-file-1234
http://www.app.montor.site/.well-known/acme-challenge/test-file-1234
http://app.montor.site/.well-known/acme-challenge/test-file-4321
http://www.app.montor.site/.well-known/acme-challenge/test-file-4321
I see only http://www.app.montor.site/.well-known/acme-challenge/test-file-1234 is accessible
hmm...
Let's change the embedded 404 to something more obvious.
Change this:
To:
RedirectMatch 409 "^(?!/\.well-known/acme-challenge/[\w-]{43}$)"
Something isn't working as expected.
  • The redirection match !43 chars fails to catch the "test-file-1234" [which only has 14 chars]
  • The permanent "/" redirection isn't being applied:
curl -I http://app.montor.site/please-redirect-me
HTTP/1.1 404 Not Found
Date: Tue, 20 Jul 2021 18:26:53 GMT
Server: Apache/2.4.41 (Ubuntu)
curl -I http://www.app.montor.site/please-redirect-me
Date: Tue, 20 Jul 2021 18:25:51 GMT
Your config must have unseen problems.
[have I mentioned how much I dislike Apache lately?]
I will try to rewrite apache config once more, thanks for your help
Hello again, i tried to run with --dry-run and --debug-challenges flags, and its worked.
But when i try to debug challenges without --dry run flag. Certbot does not create verification files. Maybe the problem is in rights?
Simulating a certificate request for app.montor.site and www.app.montor.site
http-01 challenge for app.montor.site
http-01 challenge for www.app.montor.site
Using the webroot path /var/www/app.montor.site for all unmatched domains.
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Press Enter to Continue
The dry run was successful.
I would try using --webroot with certonly instead of --apache.
And it's surprisingly worked!
(ref: /etc/letsencrypt/renewal/app.montor.site.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for app.montor.site and www.app.montor.site
Wonderful!
[not surprising to me :slight_smile:]
Cheers from Miami :beers:
#SOSCUBA
Thanks a lot! :grinning_face_with_smiling_eyes:
