403 forbidden after using letsencrypt
My domain is:www.topfabric.co.uk
My web server is (include version): apache 2.4.23
The operating system my web server runs on is (include version):Amazon Linux AMI 2018.03
My hosting provider, if applicable, is:AWS jetware lamp
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): ./certbot-auto --version = certbot 0.35.1
https://www.ssllabs.com/ssltest/analyze.html?d=topfabric.co.uk - gives “A”
https://www.ssllabs.com/ssltest/analyze.html?d=www.topfabric.co.uk - gives “A”
I made the certificate using:
./certbot-auto certonly --webroot -w /jet/app/www/default/ -d topfabric.co.uk -d www.topfabric.co.uk
Copied these lines into my topfabric.conf
Let’s Encrypt
SSLCertificateFile “/etc/letsencrypt/live/topfabric.co.uk/fullchain.pem”
SSLCertificateKeyFile “/etc/letsencrypt/live/topfabric.co.uk/privkey.pem”
SSLCACertificateFile “/etc/letsencrypt/live/topfabric.co.uk/fullchain.pem”
Tests all appear to run okay, but if I try and visit https://www.topfabric.co.uk I get a 403 forbidden.
Any help would be very welcome!
Hi @mmedia
checking your domain there is the following result ( https://check-your-website.server-daten.de/?q=topfabric.co.uk ):
http://topfabric.co.uk/
52.215.253.75 302 http://www.topfabric.co.uk/ 0.273 D
52.215.253.75 200 1.203 H
https://topfabric.co.uk/
52.215.253.75 403 0.667 M
Forbidden
https://www.topfabric.co.uk/
52.215.253.75 403 0.427 M
Forbidden
http works, https has the correct certificate
CN=topfabric.co.uk
	05.07.2019
	03.10.2019
expires in 89 days
topfabric.co.uk, www.topfabric.co.uk - 2 entries
but the http status 403 - Forbidden.
And
Let's Encrypt Authority X3 2019-07-04 2019-10-02 topfabric.co.uk, www.topfabric.co.uk - 2 entries duplicate nr. 1
it's your first Letsencrypt certificate.
So your port 443 vHost is wrong.
Compare your port 80 vHost with your port 443 vHost.
And there are different headers:
A Info: Different Server-Headers found
http:
Server: Apache/2.4.23 (Unix) OpenSSL/1.0.2h mod_fcgid/2.3.9 PHP/5.6.24
https:
Server: Apache/2.4.39 (Amazon) OpenSSL/1.0.2k-fips
But the ip is the same. Looks like your new vHost doesn't work.
Thanks a lot for your help, I’ll see if I can find anything wrong with the vHosts.
Okay, after checking through my vhost ssl config I found the problem and sorted it. Once that was rectified and apache restarted, everything sparked into life.
For other AWS Jetware Lamp users: Put the certificate paths in extra/httpd-ssl.conf with your 443 virtualhost details and make sure ec2-user can read the /live certificates. Worked for me!
Thanks so much for pointing me in the right direction.
cheers
Ah, interesting, good to know. Rechecked your domain, now there is ony one server header:
Looks like there runs a standard Amazon instance. If that instance has access to the files, it sends the header of the local instance.
If not, that's blocked and the standard Amazon header is sent.
Thanks! :+1:
