I’ve got a vhost setup with a few thousand sites on it, on a CentOS 7 machine running Apache 2.4.6 + Certbot 0.31.0. I’m in the process of issuing certs via Certbot + a cron job, which runs a command like this:
certbot --apache certonly -d jassonbautista.xyz -d www.jassonbautista.xyz
The first few certs went fast, but now that I’m a few hundred sites deep, things were moving pretty slowly (~7-8 minutes per cert).
I disabled IPv6, and that cut the times to around 4 minutes, but there’s still a very consistent 4 minute delay at a specific step in the process, between these two steps in the command output:
[~4 Minute delay]
And between these two steps mentioned in log:
2019-04-04 12:23:45,810:DEBUG:certbot_apache.configurator:Apache version is 2.4.6
[~4 Minute delay]
2019-04-04 12:27:48,633:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Once it gets to the latter step, the process only takes a few seconds, but there seems to be some kind of timeout between these steps?
Here’s a bit more of the log. I’m not the most experienced backend dev, so I’m sure I’m missing some information here. Any help or direction would be greatly appreciated.
2019-04-04 12:23:45,005:DEBUG:certbot.main:certbot version: 0.31.0
2019-04-04 12:23:45,005:DEBUG:certbot.main:Arguments: ['--apache', '-q', '-d', 'jassonbautista.xyz', '-d', 'www.jassonbautista.xyz']
2019-04-04 12:23:45,005:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2019-04-04 12:23:45,042:DEBUG:certbot.log:Root logging level set at 30
2019-04-04 12:23:45,042:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2019-04-04 12:23:45,043:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
Initialized: <certbot_apache.override_centos.CentOSConfigurator object at 0x7f7c3170a850>
Prep: True
2019-04-04 12:27:48,634:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Prep: True
2019-04-04 12:27:48,635:DEBUG:certbot.plugins.selection:Selected authenticator <certbot_apache.override_centos.CentOSConfigurator object at 0x7f7c3170a850> and installer <certbot_apache.override_centos.CentOSConfigurator object at 0x7f7c3170a850>
2019-04-04 12:27:48,635:INFO:certbot.plugins.selection:Plugins selected: Authenticator apache, Installer apache
2019-04-04 12:27:48,674:DEBUG:certbot.main:Picked account: <Account(RegistrationResource(body=Registration(status=None, terms_of_service_agreed=None, agreement=None, only_return_existing=None, contact=(), key=None, external_account_binding=None), uri=u'https://acme-v02.api.letsencrypt.org/acme/acct/51249897', new_authzr_uri=None, terms_of_service=None), a247801cefefd4727a427c22189decb6, Meta(creation_host=u'localhost.localdomain', creation_dt=datetime.datetime(2019, 2, 10, 22, 39, 49, tzinfo=<UTC>)))>
2019-04-04 12:27:48,690:DEBUG:acme.client:Sending GET request to https://acme-v02.api.letsencrypt.org/directory.
2019-04-04 12:27:48,698:INFO:requests.packages.urllib3.connectionpool:Starting new HTTPS connection (1): acme-v02.api.letsencrypt.org
2019-04-04 12:27:48,952:DEBUG:requests.packages.urllib3.connectionpool:"GET /directory HTTP/1.1" 200 658
2019-04-04 12:27:48,953:DEBUG:acme.client:Received response:
HTTP 200
