Hi everyone
I have a nodejs api deployed on a digitalocean droplet on ubuntu 20 and all runs fine.
Now i wanted to have a website for a project im doing and i wanted a different server so i created a wordpress droplet(ubuntu 20 but running apache) and im struggling getting it to work given the fact that my ssl certificate is in my original server. My question is how can i have my new wordpress droplet on the same domain using letsencrypt that i use on my main server with nginx?
This is my config on nginx
server_name psymbl.app www.psymbl.app;
set $upstream 46.101.58.206:443;
location ~ /\.well-known/acme-challenge/ {
allow all;
#default_type "text/plain";
root /var/www/letsencrypt;
try_files $uri =404;
try_files $uri $uri/ =404;
proxy_pass_header Authorization;
proxy_pass https://$upstream;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Connection “”;
proxy_buffering off;
client_max_body_size 0;
proxy_read_timeout 36000s;
proxy_redirect off;
location ~ ^/(node|socket\.io) {
#your proxy directives
proxy_pass http://localhost:3003;
proxy_set_header Connection 'upgrade';
proxy_cache_bypass $http_upgrade;
location /api {
proxy_pass http://localhost:5500;
ssl_certificate /etc/letsencrypt/live/psymbl.app/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/psymbl.app/privkey.pem; # managed by Certbot
Appreciate any help
Standard info below:
My domain is: psymbl.app
My web server is (include version): apache and nginx
The operating system my web server runs on is (include version): ubuntu 20
My hosting provider, if applicable, is: digitalocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
