Certificates for backup servers using proxy pass
Hi friends,
I've two VPS, and I would like to know if should be possible to use as "controller machine" (as described here ) one of this my two server or if is necessary a third server.
Many thanks!
Hi @dandje, it should be fine for one of the machines to be one of your web servers. It doesn’t need to be a separate machine.
OK, I proceed then will follow a short report of mine to help other users.
thanks!
Hi danjde,
I “think” you are asking, can the controller machine be an email server too. The answer is YES! Your solution sounds fine.
danday74
Hi danday74 and thanks for your kind reply,
excuse me for my bad English, the question is:
to use one of the two email servers, as “controller machine” to get the certificates for both of themselves.
Thanks again!
yes thats fine as follows:
machine 1 - is controller machine and email server and is the machine on which to execute the lets encrypt CLI commands
machine 2 - this is an email server only and it should proxy pass let’s encrypt requests to machine 1
Very thanks for your help danday74!
I wanted to be safe before doing disasters! :smiley:
Thanks again :wink:
Hi friends,
I’ve make all changes as suggested by @danday74, but when I run certbot:
certbot certonly --webroot -w /var/www/letsencrypt --expand -d server.sio4.org -d sio4.org -d www.sio4.org -d pop.sio4.org -d mail.sio4.org -d smtp.sio4.org -d server2.sio4.org [..]
Obtain the error:
Failed authorization procedure. server2.sio4.org (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://server2.sio4.org/.well-known/acme-challenge/Kqy88NRyl3ZXui2JoBa1AMRmtSkL40WdfpwKWy-KYCE: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p"
   Domain: server2.sio4.org
   Type:   unauthorized
   Detail: Invalid response from
   <html><head>
   </head><body>
   <h1>Not Found</h1>
   <p"
To date I made these changes:
  1. DNS entry: on sio4.org DNS, add record as “A” value “ctrl” to “91.205.175.213” (server.sio4.org)
  2. DNS entry: on sio4.org DNS, add record as “A” value “server2” to (backup server) 5.189.166.16
  3. DNS entry: add MX backup (server2.sio4.org -> 5.189.166.16) value on every “my” DNS domain
  4. Add to every Virtual Domain Apache (only http and not non https):
     `ProxyPass "/.well-known/acme-challenge/" "http://ctrl.server.sio4.org:80"`
  5. Maintained the Apache Letsencrypt configuration:
    Alias /.well-known/acme-challenge/ /var/www/letsencrypt/.well-known/acme-challenge/
    <Directory “/var/www/letsencrypt/.well-known/acme-challenge/”>
    Options None
    AllowOverride None
    ForceType text/plain
    avoid access to anything not resembling a challenge
    #RedirectMatch 404 “^(?!/.well-known/acme-challenge/[\w­]{43}$)”
  6. enabled on server.sio4.org Apache proxy module: a2enmod proxy
  7. Checked the Apache accuracy configuration: apachectl configtest
Should I delete the current Letsencrypt configuration/folder and run again certbot?
Any help is very appreciate, GASP! :slight_smile:
If you create /var/www/letsencrypt/test.txt, can you see it at http://server2.sio4.org/test.txt?
If you create /var/www/letsencrypt/.well-known/acme-challenge/test.txt, can you see it at http://server2.sio4.org/.well-known/acme-challenge/test.txt?
If not, your Apache configuration is still not correct yet.
