My Russian skills aren’t good enough to determine exactly what your question is I’m afraid. Perhaps you could explain a little more ?
Just looking at the domain it appears that the chain cert isn’t being served. If you used certbot or another client with the same naming scheme use fullchain.pem instead of cert.pem
Here’s a chain cert tool https://whatsmychaincert.com/?evrocompany.ru
I hope it can help
