I have a digitalocean serverpilot apache/nginx droplet with several SSL certs already in play, some for subdomains others for mapped root domains (ie. subdomain.domain.com and domain.com).
To cover future subdomain creation I want to install a wildcard ssl cert. Will this conflict with certificates I already use for existing subdomains?
The certificate itself does not dictate its' use.
That is done with the server_name and server_alias directives in (nginx) vhost config server blocks.
(servername and serveralias in Apache)
You could search through your configs to better understand what you are already using. grep -Eri 'server_name|server_alias' /etc/nginx grep -Eri 'servername|serveralias' /etc/apache2
So is that a yes? If I have an INSTALLED certificate that works for subdomain.domain.com and I set up an additional wildcard *.domain.com certificate do I need to remove all confugration relating to any subdomain(s).domain.com?
