Wildcard renewal problem
I updated the _acme-challenge.boxrec.com txt record as instructed. Did a dig to check DNS had been updated OK, it had, then hit enter to finish but certbot fetched the old DNS txt field. Now I am stuck in a loop, each time I try to update it generates a new TXT which I have to update DNS so I am always out of sync. How do I sync cerbot with the current DNS record ?
dig -t txt _acme-challenge.boxrec.com
; <<>> DiG 9.11.4-3ubuntu5.1-Ubuntu <<>> -t txt _acme-challenge.boxrec.com
_acme-challenge.boxrec.com. 7199 IN TXT “gbbnVKTxt6jO836LWS6oP1wuaxGY21lqdTihZA6RbF8”
My domain is: boxrec.com
certbot certonly --manual -d *.boxrec.com --preferred-challenges dns --server https://acme-v02.api.letsencrypt.org/directory
dns-01 challenge for boxrec.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you’re running certbot in manual mode on a machine that is not
your server, please ensure you’re okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: Y
Please deploy a DNS TXT record under the name
_acme-challenge.boxrec.com with the following value:
Before continuing, verify the record is deployed.
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. boxrec.com (dns-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect TXT record “mtySdhCDKAywfmW6vqxbfrGiJU3WPKaIoORAv-GLY3Y” found at _acme-challenge.boxrec.com
    Domain: boxrec.com
    Detail: Incorrect TXT record
2.8
Hi @johnshep
your dns txt entry is visible ( https://check-your-website.server-daten.de/?q=boxrec.com ):
	looks good
You have a standard TTL of one hour:
Domain: boxrec.com
Primary: NS1.WORLDNIC.com
Mail: namehost.WORLDNIC.com
Serial: 118112817
Refresh: 10800
Retry: 3600
Expire: 604800
TTL: 3600
num Entries: 2
So perhaps you should wait 4-5 minutes before doing the next step.
While the records don't match it will continue to fail.
You may need to insure that ALL your authoritative DNS servers are up-to-date before continuing.
Thanks Juergen,
yes I can update the DNS txt fine but it takes time to propagate and when I run certbot again it generates a different txt entry. Is there a way to keep certbot in stasis until DNS has propagated to the required txt ?
John
Yes:
Don't press Enter.
Not pressing enter means keeping the terminal link up for a prolonged period which is something my internet provider has great difficulty managing :frowning: I’m lucky to get 15 minutes without a drop out.
You could run certbot in a screen instance.
thanks Osiris, tried with Screen, now I get …
Failed authorization procedure. boxrec.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: query timed out looking up TXT for _acme-challenge.boxrec.com
    Domain: boxrec.com
    Type: None
    Detail: DNS problem: query timed out looking up TXT for
Rechecked your domain: Your SOA records are inconsistent.
Domain: boxrec.com
Serial: 119022810
Refresh: 10800
Retry: 3600
Expire: 604800
TTL: 3600
num Entries: 1
Domain: boxrec.com
Serial: 119022617
Refresh: 10800
Retry: 3600
Expire: 604800
TTL: 3600
num Entries: 1
There are two nameservers:
But different Serial numbers -> slow system.
But unboundtest.com can find the TXT record just fine:
https://unboundtest.com/m/TXT/_acme-challenge.boxrec.com/6GJPNWT7
So I’m not sure why Let’s Encrypts systems would time out.
thanks guys, this is just so painful :frowning:
