I’m trying to start from scratch using Powershell in order to generate a wildcard cert.
I ran the following:
Initialize-ACMEVault -BaseURI https://acme-v02.api.letsencrypt.org/directory
then
New-ACMERegistration -Contacts mailto:email@domain.com -AcceptTos
I got htis error.
New-ACMERegistration : Missing initial replay-nonce header
How am I supposed to set this up if I can’t register? I’m really confused on how to use the v2 with powershell / ACMEVault.
