Wildcard not working
calendarstory.com
certbot certonly --standalone --http-01-port 999 -d calendarstory.com
A valid certificate for the server / root (calenarstory.com). It did not work on the first-level domain www.
Haproxy
no
Note: According to the documentation at the URL below, an order of "example.com" or "*.example.com" is expected to generate a wildcard. I used the former.
Hi @TragicWarrior
this is wrong (and not there). A wildcard certificate has *.example.com as one name.
A certificate with example.com isn't a wildcard certificate.
But you can combine *.example.com and example.com in one certificate.
Then you can use it with example.com, www.example.com, blog.example.com etc.
@jurgenhaas , I was suspecting that was the problem. I went back just now and realized I read the documentation incorrectly. Thank you for your reply!
