My domain is: int.reboot3times.org
sudo certbot --server https://acme-v02.api.letsencrypt.org/directory -d '*.int.reboot3times.org' --manual --preferred-challenges dns-01 certonly
Failed authorization procedure. int.reboot3times.org (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.int.reboot3times.org
My web server is (include version): N/A
~ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.1 LTS"
My hosting provider, if applicable, is: DNS provider is internal bind9 deployment.
Comments:
I have a split-horizon DNS deployment, where some software deployments have two DNS domains: reboot3times.org and int.reboot3times.org - the latter being internal focused where traffic is limited solely to the internal network. The internal DNS is managed by bind9 and the external DNS is managed by Azure DNS. I’ve been having problems with HSTS and self-signed certificates recently, so I wanted to leverage LE to deploy a wildcard certificate to my internal-only domain. I can resolve the TXT record certbot tells me to create on multiple machines, so I know it’s not a resolving issue. It says it’s an NXDOMAIN error, which means that it’s trying to resolve my domain from a remote DNS server somewhere. What is the best way to move past this error?
