Hi
Is it possible to have both wildcard certificate ( *.example.com ) and basic one ( somesite.example.com ) for a separately located site at the same time?
Hi
Yes, that’s fine.
Of course, a certificate for *.example.com
can also be used to access somesite.example.com
Let’s Encrypt has rate limits, but none of them stop you from doing this.
Excellent.
*.example.com
can also be used to accesssomesite.example.com
I understand, but it is still a better option then synchronizing wildcard certificate between locations
Thank you
