Wild card cert first ssl
My domain is: example.com
dear all i need to install ssl for the myserver let’s say name is temp.example.com
and i use wild card also domain name from godaddy what the right command should i use
to get cerf for this domain and all subdomain from it
up still waiting for support
This support is mostely run by volunteers. You’ve waited a whole hour. Also, your post isn’t really that helpful: none of the questions which are required to receive help have been answered.
Therefore, I’m enclined to guess there’s a few more hours to wait until someone has patience enough to help you with your very concise question.
In the mean while, you might be interested in the following document: https://letsencrypt.org/getting-started/
i already run sudo certbot --server https://acme-v02.api.letsencrypt.org/directory -d temp.mydomain.com -d *.temp.mydomain.com --manual --preferred-challenges dns-01 certonly
i got txt to add in dns i do use godaddy get domain name and dns
so should i add txt record for every subdomain so what is the benefit of wildcard
Yes, currently (and I don't know if that's going to change) Let's Encrypt or certbot can't "mix" challenges. So if you need the dns-01 challenge for a wildcard certificate, then all hostnames must be validated by the dns-01 challenges. And for every hostname a separate TXT record is required.
The wildcard certificate is beneficial for the management of multiple domains in your webserver. With a wildcard certificate, you can make use of thousands of different labels without the need of getting a new certificate for every new hostname.
So if you have a certificate with *.example.com for just www.example.com, but you need a new website foo.example.com and perhaps later also bar.example.com, you can just use that single wildcard certificate for all those hostnames. Note: the wildcard hostname *.example.com would not cover foo.temp.example.com, as the wildcard is only valid for a single DNS label. You'd need the wildcard hostname *.temp.example.com for hostnames like foo.temp.example.com and bar.temp.example.com. Note 2: the wildcard hostname is also not valid for the "base" hostname example.com, so like you did correctly, you'd need to add *.example.com and example.com to the same certificate, requiring two TXT records indeed.
Letsencrypt allows mixed challenges, Certbot can't use that.
My *.server-daten.de + server-daten.de certificate is created that way: *.server-daten.de via dns validation, server-daten.de via http validation.
Created a test certificate:
The wildcard validation:
  "identifier": {
    "type": "dns",
    "value": "server-daten.de"
  "status": "valid",
  "expires": "2020-05-27T16:27:49Z",
  "challenges": [
      "type": "dns-01",
      "status": "valid",
      "url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/52000447/OJL95w",
      "token": "ku6-U0WvyYmGers3gfQLus3AuXjD2anOqYGTMaPXjtQ",
      "validationRecord": [
          "hostname": "server-daten.de"
  "wildcard": true
The main domain validation via http:
  "identifier": {
    "type": "dns",
  "status": "valid",
  "expires": "2020-05-27T16:27:50Z",
  "challenges": [
      "type": "http-01",
      "status": "valid",
      "url": "https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/52000448/axzYOw",
      "token": "Z-vPE51hhgQlg9t3NjTPYQU-LE9voXszfnpZ2BQgsU8",
          "url": "http://server-daten.de/.well-known/acme-challenge/Z-vPE51hhgQlg9t3NjTPYQU-LE9voXszfnpZ2BQgsU8",
          "hostname": "server-daten.de",
          "port": "80",
          "addressesResolved": [
            "85.215.2.226",
            "2a01:238:301b::1226"
          "addressUsed": "2a01:238:301b::1226"
If a client supports that, only one TXT entry is required.
Good to know it’s indeed a certbot limitation, not an ACME/Let’s Encrypt limitation.
related to that so can i have wildcard cert for subdomain and all subdomains from it
without txt record by using Let’s Encrypt
Using a TXT record is a policy requirement from the Let’s Encrypt CA in order to get a wildcard certificate. There is no way to get a Let’s Encrypt wildcard certificate without using the DNS-01 method (creating a TXT record in your DNS zone).
What do you mean by "every subdomain"? If you tried to get that certificate, you would have to set two TXT records.
yes i got it thanks for every subdomain and main one i will have txt record to be added
thanks alot for your support
