Where should /.well-known/acme-challenge/ point?
I have setup by cert using Certbotx nginx.
My app is currently receiving the /.well-known/acme-challenge endpoint giving 404.
I have tried adding the following location block above my location / and the Nginx started to give 404. I’m not sure where the acme-challenge location path should point to. /var/www/html is basically empty in my case.
        root /var/www/html;
Nginx file:
    server_name subdomain.myserver.com;
        proxy_pass https://localhost:3000;
        proxy_http_version 1.1;
        proxy_set_header Connection 'upgrade';
        proxy_set_header Host $host;
        proxy_cache_bypass $http_upgrade;
    ssl_certificate /etc/letsencrypt/live/subdomain.myserver.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/subdomain.myserver.com/privkey.pem; # managed by Certbot
    if ($host = subdomain.myserver.com) {
    } # managed by Certbot
    listen 80;
Note: I’m using a subdomain
Thanks
It should point to the same location that you pass to Certbot. Where exactly is not important.
That configuration would be suitable if you were doing something like:
certbot certonly -d subdomain.myserver.com --webroot -w /var/www/html
Hi @thellimist
simple answer: That's your choice.
Create there the two subdirectories /.well-known/acme-challenge, there a test file (file name 1234), then try to load that file via http.
If that works, use that root as your webroot parameter.
I have created file in path /var/www/html/.well-known/acme-challenge/1234 and added
        root /var/www/html;
to my Nginx. I can download the file 1234, however, running certbot renew gives
Attempting to renew cert (subdomain.myserver.com) from /etc/letsencrypt/renewal/subdomain.myserver.com.conf produced an unexpected error: Failed authorization procedure. subdomain.myserver.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://subdomain.myserver.com/.well-known/acme-challenge/somerandomkeys [2606:4700:3032::681f:43b1]: "<html>\n<head><title>404 Not Found</title></head>\n<body bgcolor=\"white\">\n<center><h1>404 Not Found</h1></center>\n<hr><center>ngin". Skipping.
  /etc/letsencrypt/live/subdomain.myserver.com/fullchain.pem (failure)
What am I missing?
Thanks
Without knowing your real domain, it’s total guesswork, but check that your domain’s IPv6 AAAA record is correct, and that your nginx listen stanza is effective for the IPv6 interface.
I mention this because the redacted error you pasted reveals that Let’s Encrypt is connecting to your server over IPv6.
Edit: ah, it’s a Cloudflare IP. That’s probably not the issue then.
If you are using --nginx, be aware that there is an issue relating to Cloudflare which leads to the kind of problem you’re having. To see whether it is relevant to you, try renewing using webroot instead of --nginx:
certbot renew -a webroot -w /var/www/html --dry-run
Ohh interesting. Cloudflare makes sense. Great catch!
FYI This worked
