Where is ssl_trusted_certificate after running "sudo /usr/local/bin/certbot-auto certonly --nginx"
I am using centos 8,
I generated certificate and private key successfully following this guide:
Running this command below:
The result is like this:
   /etc/letsencrypt/live/example.com/fullchain.pem
   /etc/letsencrypt/live/example.com/privkey.pem
As shown above, it generated one certificate and one private key.
Then I generated a nginx ssl configuration via this tool:
https://ssl-config.mozilla.org/#server=nginx&server-version=1.17.0&config=modern
# certs sent to the client in SERVER HELLO are concatenated in ssl_certificate
ssl_certificate /path/to/signed_cert_plus_intermediates;
ssl_certificate_key /path/to/private_key;
 # verify chain of trust of OCSP response using Root CA and Intermediate certs
ssl_trusted_certificate /path/to/root_CA_cert_plus_intermediates;
As shown above, there are two certificates, they are ssl_certificate and ssl_trusted_certificate, but certbot generate only one certificate.
So, where can I find the other certificate?
/etc/letsencrypt/live/example.com/chain.pem – which contains the intermediate but not the root – works.
