Account IDs posted prior to this message have all been added.
Please let us know how this works out for you - both good and bad. Did anything break? What clients have you used? Are the IP Certs compatible with applications where you wanted them?
Hi, I would like to test the behave of Caddy on shortlived and IP certificate.
Hey want to use it for ip availability check (dns-independent)
https://acme-v02.api.letsencrypt.org/acme/acct/106542644
Worked perfectly 100% ![]()
Wrote my own ACME client.
Thank you Let's Encrypt.
John S.
Don't know why my post doubled spaced ![]()
I would like to test out IP certificates as well.
https://acme-v02.api.letsencrypt.org/acme/acct/629785776 want to use to issue a cert for the mirrors site, which can be used for the devices which NOT have a dns access
Hi @mcpherrinm ,
If it's not too late, could I request access for https://acme-v02.api.letsencrypt.org/acme/acct/31488023 please? I'll be doing DoT and DoH with it, eventually for a cert with hostnames and IP addresses.
Thank you!
Hello,
My account URL is https://acme-v02.api.letsencrypt.org/acme/acct/1422386646
I plan to use it for applications that enhance privacy, such as DNS over HTTPS without bootstrap server.
Hey Matthew,
I’d love to have early access to test out IP address support in Auto Encrypt (ACME Client Implementations - Let's Encrypt) and Kitten (https://kitten.small-web.org) as part of the run-up to the launch of the Small Web with Web Numbers (as I’m calling them; Web Numbers – Aral Balkan) next year.
Account URL:
https://acme-v02.api.letsencrypt.org/acme/acct/2084338977
Thank you ![]()
Can I please test shortlived live certificates for: https://acme-v02.api.letsencrypt.org/acme/acct/31221880
thank you!
I plan to use Let’s Encrypt to issue IP certificates for my encrypted DNS.
https://acme-v02.api.letsencrypt.org/acme/acct/2822147606
I‘d like to use the service for my DNS Server (with DoH). Could I get access to short-lived?
Hope Thanksgiving turned out well for all!
I’d like to participate using ACME account: https://acme-v02.api.letsencrypt.org/acme/acct/223017260
My primary goal is to test short-lived and IP-address certificates using acme.sh, since most existing reports focus on other clients. I want to validate issuance and renewal behavior over multiple cycles and ensure that automation works reliably before considering broader deployment. I’ll be starting with only one or two stable (static) public IPs.
https://acme-v02.api.letsencrypt.org/acme/acct/2281139796
Would like to test acme.sh with Shortlive profile
Thanks for all your work. I'd like to participate in the test. Here is my account:
https://acme-v02.api.letsencrypt.org/acme/acct/61474355
I use acme.sh and JS ACME as clients
They work well and can issue certificates mixed with FQDN
Perfect for my use case
I want to get an IP certificate to test my DNS server with DoH. Thanks a lot.
https://acme-v02.api.letsencrypt.org/acme/acct/2840997026
Thank you for your great work.
If possible, please add me.
I use the IP address SSL for my personal site.
