The first time you execute certbot it will run in a special "initial" mode where it, among other, ash you to accept the Terms of Service.
And if you request a new certificate in the same run using DNS verification, certbot will provide 2 verification codes for the same dns-record as stated. I updated the DNS record two times and I did confirm it was correctly updated, but it still failed.
I believe it have newer been to to succeed this first initial run!
Is it possible to force certbot to run in this initial mode, so I can test this an extra time with extra diligence?
Output from this initial run:
# certbot certonly --manual --domains "domain.com,*.domain.com" --preferred-challenges dns-01 --manual-public-ip-logging-ok --email "mail@domain.com"
Please deploy a DNS TXT record under the name:
_acme-challenge.domain.com.
with the following value:
O2FJRuHxq31TMvVXXhFPRcbaYnkePUIfTw-JxysHVHQ
Press Enter to Continue
ZBHWQO9I4y8tEFToqemysOuaWb2RNUmOTU6sGAA1mNA
(This must be set up in addition to the previous challenges; do not remove,
replace, or undo the previous challenge tasks yet. Note that you might be
asked to create multiple distinct TXT records with the same name. This is
permitted by DNS standards.)
Before continuing, verify the TXT record has been deployed. Depending on the DNS
provider, this may take some time, from a few seconds to multiple minutes. You can
check if it has finished deploying with aid of online tools, such as the Google
Admin Toolbox: https://toolbox.googleapps.com/apps/dig/#TXT/_acme-challenge.domain.com.
Look for one or more bolded line(s) below the line ';ANSWER'. It should show the
value(s) you've just added.
Domain: domain.com
Detail: Incorrect TXT record "ZBHWQO9I4y8tEFToqemysOuaWb2RNUmOTU6sGAA1mNA" found at _acme-challenge.domain.com
Hint: The Certificate Authority failed to verify the manually created DNS TXT records. Ensure that you created these in the correct location, or try waiting longer for DNS propagation on the next attempt.
When I ran the same command again resulting in certbot not running in this "initial" mode, everything went fine and only one verification code was provided and it worked.
I also attach a copy of the certbot log.
Certbot error_log.txt (29.6 KB)
Certbot version version: 1.18.0
