What IIS settings are needed for certbot?
My domain is:test.missionassist.org.uk
I ran this command: certbot certonly --webroot --test-cert --debug-challenges -w “c:\inetpub\wwwroot”
Domain: test.missionassist.org.uk
Detail: Invalid response from
http://test.missionassist.org.uk/.well-known/acme-challenge/vrA117AaGVnJP234f5wVSWlmuNf1t0GzUFAvIx0ddEE
[51.104.239.1]: "\r\n<html
xmlns=“http”
My web server is (include version): IIS on Windows Server 2019
The operating system my web server runs on is (include version): Windows Server 2019
N/A - the server runs under Azure.
IIS Manager under Windows Server 2019
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.7.0
I have tried various things, but to no avail. --standalone fails with a timeout despite getting a quick response from a web browser running on the local machine. Let’s Debug summary shows:
All OK!
OK
No issues were found with test.missionassist.org.uk. If you are having problems with creating an SSL certificate, please visit the Let’s Encrypt Community forums and post a question there.,
However, the verbose information shows things like:
Request to: test.missionassist.org.uk/51.104.239.1, Result: [Address=51.104.239.1,Address Type=IPv4,Server=Microsoft-IIS/10.0,HTTP Status=404], Issue:
Trace:
@0ms: Making a request to http://test.missionassist.org.uk/.well-known/acme-challenge/letsdebug-test (using initial IP 51.104.239.1)
@0ms: Dialing 51.104.239.1
So, what configuration do I need for IIS to work with certbot?
Are you sure that http://test.missionassist.org.uk is correctly configured in IIS?
When I go to it, I see the “iisstart.htm” welcome page. I’m not a Windows user myself, but doesn’t that indicate that you haven’t setup an IIS binding for that domain?
Consequently, the webroot you passed to Certbot would not be correct.
Thanks. The web root in question isn’t the one I intend to use eventually; I switched to it to remove any script errors causing problems. The fact that you see the iisstart.htm indicates that IIS is serving the domain. The problem seems to be access the .well-known folder. Is it because IIS doesn’t like serving files without extensions.
http://test.missionassist.org.uk/.well-known/acme-challenge/letsdebug-test gives a 404 error, but
http://test.missionassist.org.uk/.well-known/acme-challenge/letsdebug-test.txt
displays the text file.
Putting this in the acme-challenge web.config removes the 404 error.
<?xml version="1.0" encoding="UTF-8"?>
 <configuration>
     <system.webServer>
         <staticContent>
             <mimeMap fileExtension="." mimeType="text/xml" />
         </staticContent>
     </system.webServer>
 </configuration>
See https://stackoverflow.com/questions/19950882/iis-how-to-serve-a-file-without-extension
And this appears to solve the problem!
Hi @spalmstr
you have to change that.
Read https://check-your-website.server-daten.de/?q=server-daten.de#comments - part 3 has the sample:
Create a web.config in that directory. Content:
<configuration><system.webServer><staticContent><mimeMap fileExtension="." mimeType="text/plain" /></staticContent></system.webServer></configuration>
or change your existing web.config.
PS:
Yep, that's always required, if IIS is used.
