Websockets over HTTPS (working for static website)
Hello,
My domain is: https://staging-game.play-elements.xyz/
I ran this command: sudo certbot --nginx -d staging-game.play-elements.xyz
(ref: /etc/letsencrypt/renewal/staging-game.play-elements.xyz.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for staging-game.play-elements.xyz
Certificate is saved at: /etc/letsencrypt/live/staging-game.play-elements.xyz/fullchain.pem
Key is saved at:         /etc/letsencrypt/live/staging-game.play-elements.xyz/privkey.pem
This certificate expires on 2024-02-23.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for staging-game.play-elements.xyz to /etc/nginx/sites-enabled/elements-cop
Your existing certificate has been successfully renewed, and the new certificate has been installed.
ls /etc/letsencrypt/live/staging-game.play-elements.xyz-0001
README  cert.pem  chain.pem  fullchain.pem  privkey.pem
The certificates are generated and I'm able to setup an nginx to serve a static index.html page over https (disabled for the current test). But when I start a very simple websocket test server (with nginx stopped), I can't manage to connect.
  • In chrome, the websocket connection fails with this not-helpful message:
test.html:13 WebSocket connection to 'wss://staging-game.play-elements.xyz/' failed:
(anonymous) @ test.html:13
test.html:28 WebSocket connection closed
  • using websocat, it fails with:
websocat wss://174.138.14.64:443/
websocat: WebSocketError: WebSocket SSL error: The certificate was not trusted.
websocat: error running
My web server is (include version): node v12.22.9
The server code is:
const https = require('https');
const fs = require('fs');
const options = {
  key: fs.readFileSync('/etc/letsencrypt/live/staging-game.play-elements.xyz-0001/privkey.pem'),
  cert: fs.readFileSync('/etc/letsencrypt/live/staging-game.play-elements.xyz-0001/fullchain.pem'),
const server = https.createServer(options, (req, res) => {
  res.writeHead(200, { 'Content-Type': 'text/plain' });
  res.end('Hello, secure world!\n');
server.listen(443, () => {
  console.log('HTTPS server listening ');
The operating system my web server runs on is (include version): Ubuntu 22.04.3 LTS
My hosting provider, if applicable, is: digital ocean, no firewall
certbot --version
certbot 2.7.4
So if we belive the websocat output, could it be a certificate issue? If then, how to check that?
I did some research, and found it should be fine since I'm using the fullchain file
Hi @ramabouda, and welcome to the LE community forum :slight_smile:
The certificate you just received:
Is NOT the certificate you are using here:
[notice the extra -0001 in the path]
Please show the output of:
certbot certificates
The certificate you just received Is NOT the certificate you are using here
Right, this was not the exact log I got when generating the -0001 certificate.
I previously generated a certificate (the one from the logs) with an older version of certbot that I deleted, then tried to see if it helped to remove certbot and reinstall a newer version using snap. This new version created the certificate with a -0001 in the name. I don't have any other certificate on disk AFAIK and this one is the last one I generated.
As requested:
Found the following certs:
  Certificate Name: staging-game.play-elements.xyz-0001
    Serial Number: 44a413f24ab8de66b73595d0d1d1b25e52a
    Key Type: ECDSA
    Domains: staging-game.play-elements.xyz
    Expiry Date: 2024-02-23 22:02:36+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/staging-game.play-elements.xyz-0001/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/staging-game.play-elements.xyz-0001/privkey.pem
That seems to be making a call directly to the IP [not the name].
If so, that will surely always return:
I agree with my fellow volunteer that using the IP address instead of the hostname is likely the issue here: this is because the certificate is only valid for the subject alternative names listed on the certificate and the IP address is not part of that. (Note that it is possible to include IP addresses in the SAN of certificates, but Let's Encrypt does not offer that.)
That said:
Please don't forcibly renew an already perfectly fine certificate in the future: it does not help in the slightest: you'd simply get an almost identical certificate, which does not help at all. It only adds more load to the Let's Encrypt systems and can lead to you hitting rate limits.
That was indeed the issue, it makes total sense. A huge thank you for your help!
