Website not secure after successful installation of certificate
clinkino.in
My web server is (include version): Ubuntu 18.04
My hosting provider, if applicable, is: Digitalocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): https://certbot.eff.org/lets-encrypt/ubuntubionic-apache Followed this one
As per requirements of digitalocean , I created virtual host also and followed as per documentation. Everything gone well. But in browser it is showing not secured
Hi @matamrd
your certificate is ok. But you have some mixed content - https://check-your-website.server-daten.de/?q=clinkino.in#html-content
Images with http links, change these to https. Sample:
http://clinkino.in/wp-content/uploads/2020/02/Transparent-ConvertImage.jpg
I deleted images with http .I checked every media. All are with https link only. But it is still showing site is not secured
Then recheck the site to see, if there are additional errors - https://check-your-website.server-daten.de/?q=clinkino.in - ah, there is a new check, again two images with http link.
