if standalone works obviously its not a firewall or whatever else issue
But standalone no longer works.
it always works
I don't understand why you keep saying they work, when the LE logs show a connection problem:
I renewd today via standalone but i thought the title was clear enough.
I only shut the vhost down as theres really no need to stop anything else. Webroot option dont work
That can't be possible.
It would hit the same firewall problem.
[Apache is not a firewall - stopping it can't stop a firewall problem].
Unless...
What else do you "stop"?
What shows?:
systemctl status firewalld
sudo firewall-cmd --list-all
firewalld is notinstalled
edit
ufw status
Status: active
To Action From
22 ALLOW Anywhere
80 ALLOW Anywhere
443 ALLOW Anywhere
22 (v6) ALLOW Anywhere (v6)
80 (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
edit2
i have fail2ban but theres nothing in http jail only ssh jail
edit3
but again standalone works so my guess is your error is misleading. Its not a firewall issue
edit4
unless theres something with the provider but i doubt that. I dont know
You are going to need to prove that.
I told you i renewd the certificate today . But still it seems hard for you to believe. Don't you have logs ?
Most of the helpers here are unpaid volunteers. We don't have access to system logs.
But, just because once you could renew with standalone does not prove you do not have a firewall blocking certain IP. Let's Encrypt validates from multiple locations each time and the IP addresses often vary from one request to the next. Maybe you just got lucky the IP addresses LE used weren't blocked that one time.
Below is the public log that shows 3 certs from staging and one from production. I don't know how this helps but thought it worth posting anyway. There is also a successful challenge cache involved that can complicate such tests.
And, there was a gap of just over 3 months between the Jun26 expiration and the Oct03 new issuance
And I did say that you couldn't have - LOL.
My "proof" is that LE can't reach your site via HTTP [as denoted many times in this topic].
Now, where is your proof?
[that you did renew using HTTP-01 authentication (with --standalone option)]
Recall: I asked for "proof"
Saying "I told you so" isn't "proof".
What's the output of ss -tlpn src :80 ? (sudo should print more stuff)
Tell us both without and with standalone running.
(I'm not sure it'll work but you can try certbot renew --standalone --dry-run --debug-challenges, then ctrl-Z then fg to pull it back.)
Most of the people on this Community are just volunteers and only have publicly known info (such as certificate transparancy logs or connection attempts) or the info provided by the user.
ss -tlpn src :80
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 511 *:80 *:* users:(("apache2",pid=2421470,fd=4),("apache2",pid=2420580,fd=4),("apache2",pid=2420579,fd=4),("apache2",pid=2420578,fd=4),("apache2",pid=2419623,fd=4),("apache2",pid=2419622,fd=4),("apache2",pid=2419620,fd=4),("apache2",pid=2419489,fd=4),("apache2",pid=2419471,fd=4),("apache2",pid=2419412,fd=4),("apache2",pid=2419408,fd=4))
^Z
[1]+ Stopped /usr/bin/certbot renew --standalone --dry-run
root@localhost:~# ss -tlpn src :80
LISTEN 3 5 *:80 *:* users:(("certbot",pid=2421797,fd=8))
by the way here what i got after i fg:
Challenge failed for domain benedicte-pavageau.com
Challenge failed for domain www.benedicte-pavageau.com
http-01 challenge for benedicte-pavageau.com
http-01 challenge for www.benedicte-pavageau.com
Failed to renew certificate benedicte-pavageau.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/benedicte-pavageau.com/fullchain.pem (failure)
Domain: benedicte-pavageau.com
Type: connection
Detail: 172.105.247.238: Fetching
http://benedicte-pavageau.com/.well-known/acme-challenge/1jN3vhYw37tRFrj7g2j4ycVWXaWCmEzCmHRsxdZMU3w:
Timeout after connect (your server may be slow or overloaded)
Domain: www.benedicte-pavageau.com
Type: connection
Detail: 2a01:7e01::f03c:93ff:fe31:e388: Fetching
http://www.benedicte-pavageau.com/.well-known/acme-challenge/4ojkG5t1eI6nJCrHIeK-wuYcc7T5LEihjAO1JehiPfQ:
But THEN immediately after when i retried : /usr/bin/certbot renew --standalone --dry-run
Processing /etc/letsencrypt/renewal/benedicte-pavageau.com.conf
Simulating renewal of an existing certificate for benedicte-pavageau.com and www.benedicte-pavageau.com
new certificate deployed without reload, fullchain is
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/benedicte-pavageau.com/fullchain.pem (success)
And again, unless there's something with linode servers, but i already installed many of them and renewal always worked
[edit] And there's more, that sounds crazy to me that ip from webroot would be blocked, and not the one from standalone, as we could assume they both from the same range.
And even if not, why the ip would be blocked in the first place ? As i recall, from the beginning i need to use standalone
As a reminder , the cron looks like this
43 1 * * * /etc/init.d/apache2 stop
43 1 * * * /usr/bin/certbot renew --standalone --quiet >> /tmp/error.log 2>&1
45 1 * * * /etc/init.d/apache2 restart
I don't want to shut the server down for two minutes straight
[edit] even if its not facebook
and what i meant when i said errors where misleading is look at these ![]()
/usr/bin/certbot renew --webroot --webroot-path /usr/share/wordpress --dry-run
Processing /etc/letsencrypt/renewal/osteopathe-brusquant.fr.conf
Simulating renewal of an existing certificate for osteopathe-brusquant.fr and www.osteopathe-brusquant.fr
http-01 challenge for osteopathe-brusquant.fr
http-01 challenge for www.osteopathe-brusquant.fr
Using the webroot path /usr/share/wordpress for all unmatched domains.
/etc/letsencrypt/live/osteopathe-brusquant.fr/fullchain.pem
/etc/letsencrypt/live/osteopathe-brusquant.fr/fullchain.pem (success)
/usr/bin/certbot renew --webroot-path /usr/share/wordpress --dry-run
Challenge failed for domain osteopathe-brusquant.fr
Failed to renew certificate osteopathe-brusquant.fr with error: Some challenges have failed.
/etc/letsencrypt/live/osteopathe-brusquant.fr/fullchain.pem (failure)
Domain: osteopathe-brusquant.fr
Type: connection
Detail: 172.233.248.74: Fetching
https://osteopathe-brusquant.fr/.well-known/acme-challenge/gBfbjhteJDG83WXfIz2HM4wsvKir9GkKjpGcvI8p8i8:
although the truth is, there's a parse failure right ?
That is a terrible plan.
Stopping and restarting Apache can be done by certbot using --deploy-hook.
And it will only do so when the cert actually needs to be renewed - not everyday.
That said, I don't see where you stopped Apache and still feel like the renewals shown are based on previously cached authentication - not anything done today.
