We facing issue javax.net.ssl.SSLHandshakeException
My domain is: In our many server we getting the error while try to access our application .
android 7 and less version also In some case we getting same error in android 12 also
javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
at com.android.org.conscrypt.OpenSSLSocketImpl.startHandshake(OpenSSLSocketImpl.java:328)
at com.android.okhttp.internal.http.SocketConnector.connectTls(SocketConnector.java:103)
at com.android.okhttp.Connection.connect(Connection.java:143)
at com.android.okhttp.Connection.connectAndSetOwner(Connection.java:185)
at com.android.okhttp.OkHttpClient$1.connectAndSetOwner(OkHttpClient.java:128)
at com.android.okhttp.internal.http.HttpEngine.nextConnection(HttpEngine.java:342)
at com.android.okhttp.internal.http.HttpEngine.connect(HttpEngine.java:331)
at com.android.okhttp.internal.http.HttpEngine.sendRequest(HttpEngine.java:249)
at com.android.okhttp.internal.huc.HttpURLConnectionImpl.execute(HttpURLConnectionImpl.java:437)
at com.android.okhttp.internal.huc.HttpURLConnectionImpl.connect(HttpURLConnectionImpl.java:114)
at com.android.okhttp.internal.huc.HttpURLConnectionImpl.getOutputStream(HttpURLConnectionImpl.java:245)
at com.android.okhttp.internal.huc.DelegatingHttpsURLConnection.getOutputStream(DelegatingHttpsURLConnection.java:218)
at com.android.okhttp.internal.huc.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:25)
at com.google.android.datatransport.cct.CctTransportBackend.doSend(CctTransportBackend.java:303)
at com.google.android.datatransport.cct.CctTransportBackend.lambda$bLAzIpNF4NtapXlUpPVGhzxyNT8(CctTransportBackend.java)
at com.google.android.datatransport.cct.-$$Lambda$CctTransportBackend$bLAzIpNF4NtapXlUpPVGhzxyNT8.apply(lambda)
at com.google.android.datatransport.runtime.retries.Retries.retry(Retries.java:54)
at com.google.android.datatransport.cct.CctTransportBackend.send(CctTransportBackend.java:372)
at com.google.android.datatransport.runtime.scheduling.jobscheduling.Uploader.logAndUpdateState(Uploader.java:146)
at com.google.android.datatransport.runtime.scheduling.jobscheduling.Uploader.lambda$upload$1$Uploader(Uploader.java:105)
at com.google.android.datatransport.runtime.scheduling.jobscheduling.-$$Lambda$Uploader$DXUaNZ7S78mHsDrcqc_9ECz1Ymg.run(lambda)
at com.google.android.datatransport.runtime.SafeLoggingExecutor$SafeLoggingRunnable.run(SafeLoggingExecutor.java:47)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
at java.lang.Thread.run(Thread.java:818)
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
This has been talked about for years.
There is no surprise that any new roots are unknown and untrusted by such old operating systems.
This sounds like your devices don't trust Let's Encrypt's root certificate. We previously had a cross-sign from another CA, but that is expiring, so going forward, devices need to trust Let's Encrypt directly. However, it is possible there's something else wrong.
See Shortening the Let's Encrypt Chain of Trust - Let's Encrypt
What happens if you try to visit https://valid-isrgrootx1.letsencrypt.org/ on one of these devices?
