Verification issue
My domain is: lingsshop.ca
during verification step, I press the text link,
and then goes to the first page of website instead of the text file.
Godaddy
windows professional
Godaddy
c panel
do not know this
Hi @daleyang
I don't understand your "verification step".
Checking your domain there are three certificates ( https://check-your-website.server-daten.de/?q=lingsshop.ca#ct-logs ):
Let's Encrypt Authority X3 2019-05-21 2019-08-19 lingsshop.ca, www.lingsshop.ca
2 entries
Let's Encrypt Authority X3 2019-01-04 2019-04-03 lingsshop.ca
1 entries
Go Daddy Secure Certificate Authority - G2 2018-12-31 2019-12-31 lingsshop.ca, www.lingsshop.ca
2 entries
Two Letsencrypt, both expired, one from GoDaddy.
Perhaps share a screenshot of that:
Hi, JuergenAuer,
for the Godaddy certificate, I do not know, I did not purchase it before.
for the two expired Let’s Encrypt, I try to get a new SSL cerficate, but cannot verify the text linkage after I copy the two text file to the specified directory, it will show the website first page automatically, and not the text file.
2019-08-23
Thanks for helping!
let me know if there is an option that I can get the free SSL permanently, and no need to update every three months.
Thanks again
Dale
Ah, that's the missing information.
So you use ZeroSSL and the manual validation via http-challenge.
But checking your domain that can't work ( https://check-your-website.server-daten.de/?q=lingsshop.ca ):
http://lingsshop.ca/
160.153.92.39 301 https://lingsshop.ca 0.364 A
http://www.lingsshop.ca/
160.153.92.39 301 https://www.lingsshop.ca 0.357 A
https://www.lingsshop.ca/
160.153.92.39 301 https://lingsshop.ca/ 6.573 N
Certificate error: RemoteCertificateChainErrors
https://www.lingsshop.ca 301 https://lingsshop.ca/ 4.886 N
160.153.92.39 200 7.870 N
https://lingsshop.ca 200 5.730 N
http://lingsshop.ca/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
160.153.92.39 301 https://lingsshop.ca 0.366 A
Visible Content: Moved Permanently The document has moved here .
http://www.lingsshop.ca/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
160.153.92.39 301 https://www.lingsshop.ca 0.350 A
There is a redirect /.well-known/acme-challenge/random-filename to your start page.
So Letsencrypt can't validate the file.
You have root access. So you should be able to install an own client.
Read
Then select a client, perhaps Certbot:
Then you don't need to validate your domain manual.
The info above is a little odd - you are using Godaddy, you are saying you have a "root shell" access, but the same time you have specified "Windows Pro" as the OS running on your server. I believe there might be some misunderstanding there, since Godaddy does have Windows hosting as far as I know, but that would be using Windows Server 2016. So perhaps Windows Pro and the "root shell" in your answers are related to your PC rather than the server you have. In which case you might not have sufficient access to install certbot, but might try some other clients indeed.
As for ZeroSSL step - as pointed out by @JuergenAuer above, you have a redirection set up, so verification files cannot be accessed. That explains why upon clicking on the link you are redirected to the home page of your site. Once you remove or alter that redirection, the process should work.
You are right, they are the setup for my PC. I am not a IT personal, sorry for the confusion.
another question:
how to remove or alter the redirection? I am really no clue how to do it.
Thanks a lot
Dale
You use cPanel.
Looks like your redirect http -> https is wrong. The folder and file name is removed.
There should be an option to configure such a redirect. Perhaps share a screenshot.
please check if this is right?
or need to setup somewhere else in C panel.
Thanks
There is no redirect defined.
So you have the redirect on another place.
Perhaps in your software or .htaccess.
You have to find that redirect.
when I input the link manually in the browser, the text was displayed correctly.
when I click the linkage at the FREE SSL Certificate Wizard verification page, the first couple of seconds, the link shows right, and then goes to home page of my website directly.
if it is redirect issue, when I input the address in the browser, it should redirect to home page of the my website as well. Please correct me if I am wrong, thanks.
Create a test file in /.well-known/acme-challenge, file name 1234 with content, then try to load that file.
Perhaps it's a bot detection that creates that redirect.
Use the "check-your-website" tool to check the complete url
http://lingsshop.ca/.well-known/acme-challenge/1234
created 1234 file, it looks good.
2019-08-24%20(1)
The fatal part is highlighted.
Please help me to figure it out, I guess this issue will be a common issue for most of Godaddy customers in the near future.
Thanks
That's the old result, that's irrelevant. Results are saved, that's the yesterday - result.
The new is good: https://check-your-website.server-daten.de/?q=lingsshop.ca%2F.well-known%2Facme-challenge%2F1234
160.153.92.39 200 0.347 H
http://www.lingsshop.ca/.well-known/acme-challenge/1234
160.153.92.39 200 0.350 H
https://lingsshop.ca/.well-known/acme-challenge/1234
160.153.92.39 200 4.794 N
https://www.lingsshop.ca/.well-known/acme-challenge/1234
160.153.92.39 200 4.627 N
160.153.92.39 301 http://lingsshop.ca/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 1.143 D
Visible Content:
160.153.92.39 404 2.396 A
Not Found
There is no redirect. Not the 1234, not the standard check. Instead, there is the expected result http status 404 - Not Found.
Looks like you have removed the redirect.
So try it again to create a certificate.
PS: No, one thing is curious. http + www + /.well-known/acme-challenge/random-filename is redirected to the non-www version.
But not the test file. That's curious.
It's possible there is a bot detection that checks some things. So if Letsencrypt tries to validate the file, it's redirected again.
If it doesn't work: Ask your hoster if there is such a bot detection.
Thanks for helping, I called Godaddy, it looks that the problem of redirecting was caused by Godaddy, they update it for TEXT file, I do not know what is exactly mean.
Now it is ok now.
