Summary
Requesting certs for apps.yfeldman.com and *.apps.yfeldman.com using Caddy and DNS challenge. Have recently changed namserver for apps.yfeldman.com from AWS Route 53 to deSEC. Certs were obtained successfully for apps.yfeldman.com but not the wildcard *.apps.yfeldman.com as LE is checking the old nameservers, although unboundtest.com etc all show the new ones.
Details
I own yfeldman.com which I am using with Fastmail for email. Fastmail manage DNS. I use the subdomains apps.yfeldman.com and various *.apps.yfeldman.com for self hosted apps. Fastmail allows customising their DNS settings and I have set up NS records there for apps.yfeldman.com to point to the nameservers of deSEC, a well known DNS host. (I couldn't use Fastmail for this as they don't have a API caddy can use.) Until today I used AWS route 53 instead of deSEC.
I set up Caddy with their deSEC plugin and configured it to obtain certs for apps.yfeldman.com and *.apps.yfeldman.com
It successfully obtained certs for yfeldman.com but it can't obtain the wildcard. Logs say:
Mar 27 17:50:58 vincentio caddy[2362805]: {"level":"error","ts":1711561858.7265172,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.apps.yfeldman.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.apps.yfeldman.com] solving challenges: waiting for solver certmagic.solverWrapper to be ready: checking DNS propagation of \"_acme-challenge.apps.yfeldman.com\": NS ns-1977.awsdns-55.co.uk. returned REFUSED for _acme-challenge.apps.yfeldman.com. (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/142204064/15558128904) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
The logs show LE is still checking AWS although it should have picked up the new nameservers as indicated by:
- The old NS had a short TTL which is many times passed since the change
- Checking unboundtest.com for apps.yfeldman.com and _acme-challenge.apps.yfeldman.com all show it picking up the correct NS
- The non wildcard cert worked, so LE must be able to see the new NS?!
I also note:
- This config has worked fine till now with AWS and I have made no changes other than the move to deSEC and telling Caddy to use deSEC instead of AWS for validation
- I have confirmed the challenge records are being created
- I chose DNS verification as the domain points to a non publicly routable IP
My domain is: apps.yfeldman.com
I ran this command: Caddy
My web server is (include version): Caddy v2.7.6
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: n/a
or certbot-auto --version
if you're using Certbot): Caddy
