My domain is: kasdivi.com
I start doveot
Apr 19 11:04:09 triggerfish dovecot[91350]: imap-login: Error: Failed to initialize SSL server context: Can't load SSL certificate (ssl_cert setting): The certificate is empty: user=<>, rip=200.6.151.76, lip=209.160.65.133, session=<pclhZnQW9+rIBpdM>
Apr 19 11:04:11 triggerfish dovecot[91350]: auth: Fatal: No passdbs specified in configuration file. PLAIN mechanism needs one
Apr 19 11:04:11 triggerfish dovecot[91348]: master: Error: service(auth): command startup failed, throttling for 4.000 secs
Apr 19 11:04:11 triggerfish dovecot[91350]: imap-login: Disconnected: Auth process broken (disconnected before auth was ready, waited 2 secs): user=<>, rip=200.6.151.76, lip=209.160.64.187, session=<k/F9ZnQW+urIBpdM>
apach24
Freebsd 13.2
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.7.4
Maybe there are multiple ssl_cert across multiple files? Can you post doveconf -n output here? (Put three backticks ``` on a line before and after pasting it to use code formatting)
ok th appears to be self inflicted. I was trying to deal with the issue bt changing the symbolic lines with Links to the actual certificate; When I do certbot -certificate I now get
Renewal configuration file /usr/local/etc/letsencrypt/renewal/kasdivi.com.conf produced an unexpected error: expected /usr/local/etc/letsencrypt/live/kasdivi.com/cert.pem to be a symlink. Skipping.
If only once, you could just "certbot delete --cert-name XYZ" that cert and obtain another.
Note: Don't mess with anything within the /etc/letsencrypt/ folders directly - use certbot to do whatever you need it to do.
