Using certbot --apache to get ecdsa.- How?
A little information for you all.
I had hoped that the command below would produce a ECC cert and not a ECDSA and not 128bit. But it seems like the options after --apache2 does not work with certbot.
So how do i do this while using the --apache command ?
vintagehifi.dk
certbot --apache --key-type ecdsa --elliptic-curve secp384r1 -d vintagehifi.dk -d www.vintagehifi.dk
(ref: /etc/letsencrypt/renewal/vintagehifi.dk.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for vintagehifi.dk and www.vintagehifi.dk
Certificate is saved at: /etc/letsencrypt/live/vintagehifi.dk/fullchain.pem
Key is saved at: /etc/letsencrypt/live/vintagehifi.dk/privkey.pem
This certificate expires on 2025-11-03.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Deploying certificate
Successfully deployed certificate for vintagehifi.dk to /etc/apache2/sites-enabled/000-default-le-ssl.conf
Successfully deployed certificate for www.vintagehifi.dk to /etc/apache2/sites-enabled/000-default-le-ssl.conf
Your existing certificate has been successfully renewed, and the new certificate has been installed.
certbot certificates
Found the following certs:
Certificate Name: vintagehifi.dk
Serial Number: 5b240d24ede40e0100d9684de954d2ec6fa
Key Type: ECDSA
Domains: vintagehifi.dk www.vintagehifi.dk
Expiry Date: 2025-11-03 08:00:58+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/vintagehifi.dk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/vintagehifi.dk/privkey.pem
Apache2 lastest
Ubuntu 24.04
From Google:
ECDSA, or Elliptic Curve Digital Signature Algorithm, is a cryptographic algorithm used to create digital signatures. It's a variant of the Digital Signature Algorithm (DSA) that uses elliptic curve cryptography (ECC)
It's pretty much done what you asked for. Key bit size has a different meaning when talking about RSA vs EC
You are right. It set in /etc/letsencrypt/options-ssl-apache.conf
SSLCipherSuite ECDHE-ECDSA-AES256-GCM-SHA384
SSLHonorCipherOrder on
Thx
