Use of "http-01-port" as flag (not during testing)
I'm using certbot standalone in docker. I would like to use --http-01-port.
When I specify http-01-port = 81 in the config file it works.
When I specify --http-01-port 81 as a command line flag, it errors:
certbot: error: unrecognized arguments: --http-01-port 81
The docs are confusing as it's mentioned in the "testing" section:
The following flags are meant for testing and integration purposes only
...But I've seen this flag used in tutorials and StackOverflow and here - even when not testing.
So to summarize:
  • can I use it as a flag (or only in the config file)?
  • can I use it even when not testing?
Hi @lonix1,
Can you post the entire certbot line and which version of certbot you’re using please?
That's all there is unfotunately. It's run in docker, so docker logs certbot gives:
usage:
certbot [SUBCOMMAND] [options] [-d DOMAIN] [-d DOMAIN] ...
Certbot can obtain and install HTTPS/TLS/SSL certificates. By default,
it will attempt to use a webserver both for obtaining and installing the
certificate.
certbot: error: unrecognized arguments: --http-01-port 80
I'm using version certbot/certbot:v0.38.0
Is it possible to use this option as a flag, and when not testing (i.e. staging server)?
Ok I see there is a new version, 0.39.0, let me try that first and see what it says…
Nope, docker logs certbot gives:
usage:
certificate.
Is it actually possible to use this option 1) as a flag, and 2) when not testing (i.e. not "staging")?
Interesting, this is what I get while testing that flag.
$ sudo docker run -P certbot/certbot:v0.38.0 certonly --standalone --http-01-port 81 --register-unsafely-without-email --agree-tos
Registering without email!
Please enter in your domain name(s) (comma and/or space separated)  (Enter 'c'
to cancel): An unexpected error occurred:
EOFError
Interesting! Thanks for looking into it Phil!
But then I don’t understand how all those tutorials/etc manage to use this option??? Maybe something changed in the interim.
My workaround: it works for me, but only when I use it in the config file. And even when not testing.
I would prefer to use it as a flag, as then I can have more control in my workflow (scriptable) and less config files, but at least there’s a workaround.
Should I open an issue on github?
Do you have the same issue without using docker on certbot v0.38.0? I’m doubting that you will, but it’s worth checking. If you do have the same issue then at that point I’d open up a github issue.
It gets weirder - I took all the stuff from the config file and translated it to flags, so I run this:
docker run \
  -v certbot_data:/etc/letsencrypt/ \
  certbot/certbot:v0.38.0 \
  certonly \
  --standalone \
  --http-01-port 80 \
  --non-interactive \
  --rsa-key-size 4096 \
  --deploy-hook /etc/letsencrypt/foo/bar/baz.sh \
  --email me@example.com \
  --agree-tos \
  -d example.com -d www.example.com
And that works.
So the problem is the config file
  • When there is a config file, it doesn’t recognize the --http-01-port 80 flag
  • When there isn’t a config file it does recognize it
I would open a github issue with your findings. Nice research!
Thanks for confirming on your end. I opened an issue.
Can you clarify which config file?
A renewal file in /etc/letsencrypt/renewal?
Or a file that you are passing to -c/--config (e.g. cli.ini)?
I'm a bit puzzled by @Phil's confirmation - it seems like it worked for him and he ^C'd the email prompt?
@_az I mean the certbot config file, typically in /etc/letsencrypt/cli.ini
When I have that then I can’t use the flag (I get the error above). But when I move all the config in the file to flags instead, then the --http-01-port flag works without error.
Thanks. Couldn’t reproduce, though :frowning: .
$ cat /tmp/certbot-config/cli.ini
http-01-port = 1234
$ sudo docker run -v /tmp/certbot-config:/etc/letsencrypt --rm -it certbot/certbot:v0.38.0 \
-c /etc/letsencrypt/cli.ini certonly --standalone --http-01-port 4321 \
-d example.com --dry-run
http-01 challenge for example.com
Challenge failed for domain example.com
@az I had a lot more than one config option in the config file. I’ll play around with it some more to track down the issue.
Thanks for trying to repro on your end, it helps.
Awesome. There are a few bugs in the ConfigArgParse library that Certbot uses (and that ultimately produces this error), so an exact way to reproduce would be a great thing to add to that issue.
@Phil, @_az
I’ve tried many different ways, and can’t find an exact cause.
Since you guys can’t repro, the only explanation is this is a docker config problem.
That said, I did end up answering my original question:
  • yes the option can be used as a flag or in the config file
  • yes it can be used not just during testing (so the docs are incorrect)
I’m going to close that github issue. Thanks for assisting!
Just one last question - are you driving Docker using an API, perhaps?
Because how you split the CLI arguments tends to matter. If you pass in --http-01-port 8081 as a single string in the cmd array, then it will error like you describe.
The shell equivalent of doing so is by wrapping that part in quotes:
$ sudo docker run -v /tmp/certbot-config:/etc/letsencrypt --rm certbot/certbot:v0.31.0 \
certonly --standalone "--http-01-port 4321" \
usage:
certificate.
certbot: error: unrecognized arguments: --http-01-port 4321
No it turns out (I think at least) that it’s a yaml thing - docker-compose.yml file’s command was:
command:
  - certonly
  - --http-01-port=4321        # <------- gnu style option needs equals
  - --foo
  - --bar
  - -baz
  - -d example.com             # <------- unix style option needs space
This is not typically done, so there’s no docker docs on it, but it’s valid yml. It’s better to do it this way to keep it neat, commentable for each line, and easily modifiable via ansible. But then you need to know this quirk of yml which is that the long-form argument must use an = and doesn’t require escaping!
Thanks again and sorry for the false positive! :cry:
