Hello
I have a small problem with the SSL certificate from LetsEncript.
The problem only occurs when the homepage is opened on the smartphone. If the message is aborted, the homepage will still be displayed. On a PC/Laptop/MAC everything works without a message.
The following error message appears:
Domain: www.baumelertaxi.ch
Title: No certificates found
Text: The browser has requested a certificate. If you agree to this request, the application can now use this certificate with the servers. DI requesting server has been detected as xxx. Only agree to this request if you trust the application.
You can install certificates from a PKCS#12 file with the file extension .pfx or p12.
Here par Infos about the System (Server)
Windows 2012 R2
IIS 8.5
LetsEntcript: Tool from https://github.com/pkisharp/win-acme (With this tool I only have to say create certificate and for which domain, afterwards the tool does everything itself and enters it in the IIS.)
How can I make the message disappear on the smartphone? Because the message confuses some of the visitors, many do not dare to click on Cancel and leave the homepage again.
