In first thread my ip not in blocked 103.136.163.71
The only thing I can think of (within your server) to check is that ca-certificates.crt file.
The size "213920" doesn't make sense.
If you want to test around that, try:
mv /etc/ssl/certs/ca-certificates.crt /etc/ssl/certs/ca-certificates.crt.big
cp /snap/core20/1611/etc/ssl/certs/ca-certificates.crt /etc/ssl/certs/ca-certificates.crt
Then again:
curl -Iv https://acme-v02.api.letsencrypt.org
curl -Iv https://acme-v02.api.letsencrypt.org --ca-cert /etc/ssl/certs/ca-certificates.crt
both commands are the same, fyi my server use Debian 10 and ISPConfig as cpanel, other my server work normaly
And one last set of tests:
dig acme-v02.api.letsencrypt.org +short
openssl s_client -connect acme-v02.api.letsencrypt.org:443 | head
root@boneto:/home/ispconfig3_install# dig acme-v02.api.letsencrypt.org +short
prod.api.letsencrypt.org.
ca80a1adb12a4fbdac5ffcbc944e9a61.pacloudflare.com.
172.65.32.248
root@boneto:/home/ispconfig3_install# openssl s_client -connect acme-v02.api.letsencrypt.org:443 | head
write:errno=104
CONNECTED(00000003)
no peer certificate available
SSL handshake has read 0 bytes and written 320 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
What shows?:
curl -Ik https://acme-v02.api.letsencrypt.org
[definitely my last test]
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to acme-v02.api.letsencrypt.org:443
I'm done.
Now you may need to do some sort of traceroute and/or tcpdump.
If I look at OpenSSL SSL_connect: SSL_ERROR_SYSCALL ยท Issue #9566 ยท openssl/openssl ยท GitHub it might be due to TLS cipher (or protocol?) differences between the ACME server endpoint and the client.
What exact version of OpenSSL is installed?
Can you show the output of this:
curl -vv http://r3.o.lencr.org
Also,
openssl version
curl --version
The first command should help figure out if there is network connectivity. The second two can help figure out if you have a library issue.
You may also have a firewall issue on your end.
root@boneto:~# curl -vv http://r3.o.lencr.org
* Expire in 0 ms for 6 (transfer 0x55df42029d40)
* Expire in 1 ms for 1 (transfer 0x55df42029d40)
* Expire in 0 ms for 1 (transfer 0x55df42029d40)
* Expire in 2 ms for 1 (transfer 0x55df42029d40)
* Expire in 4 ms for 1 (transfer 0x55df42029d40)
* Expire in 3 ms for 1 (transfer 0x55df42029d40)
* Expire in 8 ms for 1 (transfer 0x55df42029d40)
* Expire in 5 ms for 1 (transfer 0x55df42029d40)
* Expire in 6 ms for 1 (transfer 0x55df42029d40)
* Expire in 7 ms for 1 (transfer 0x55df42029d40)
* Expire in 16 ms for 1 (transfer 0x55df42029d40)
* Expire in 10 ms for 1 (transfer 0x55df42029d40)
* Expire in 11 ms for 1 (transfer 0x55df42029d40)
* Expire in 14 ms for 1 (transfer 0x55df42029d40)
* Expire in 50 ms for 1 (transfer 0x55df42029d40)
* Trying 119.110.115.186...
* TCP_NODELAY set
* Expire in 149971 ms for 3 (transfer 0x55df42029d40)
* Expire in 200 ms for 4 (transfer 0x55df42029d40)
* Connected to r3.o.lencr.org (119.110.115.186) port 80 (#0)
> GET / HTTP/1.1
> Host: r3.o.lencr.org
> User-Agent: curl/7.64.0
> Accept: */*
< HTTP/1.1 200 OK
< Server: nginx
< Content-Length: 0
< Cache-Control: max-age=9082
< Expires: Wed, 07 Sep 2022 16:53:50 GMT
< Date: Wed, 07 Sep 2022 14:22:28 GMT
< Connection: keep-alive
* Connection #0 to host r3.o.lencr.org left intact
root@boneto:~# openssl version
OpenSSL 1.1.1n 15 Mar 2022
root@boneto:~# curl --version
curl 7.64.0 (x86_64-pc-linux-gnu) libcurl/7.64.0 OpenSSL/1.1.1n zlib/1.2.11 libidn2/2.2.0 libpsl/0.20.2 (+libidn2/2.0.5) libssh2/1.8.0 nghttp2/1.36.0 librtmp/2.3
Release-Date: 2019-02-06
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtmp rtsp scp sftp smb smbs smtp smtps telnet tftp
Features: AsynchDNS IDN IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz TLS-SRP HTTP2 UnixSockets HTTPS-proxy PSL
@JamesLE we have new logs
requests.exceptions.SSLError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by SSLError(SSLError("bad handshake: SysCallError(104, 'ECONNRESET')")))
2022-09-07 16:35:16,189:ERROR:certbot.log:An unexpected error occurred:
2022-09-07 16:35:16,539:DEBUG:certbot.main:certbot version: 0.31.0
2022-09-07 16:35:16,539:DEBUG:certbot.main:Arguments: ['--domains', 'dites.lldikti2.id']
2022-09-07 16:35:16,539:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-09-07 16:35:16,546:DEBUG:certbot.log:Root logging level set at 20
2022-09-07 16:35:16,546:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-09-07 16:35:16,547:INFO:certbot.storage:Attempting to parse the version 1.5.0 renewal configuration file found at /etc/letsencrypt/renewal/www.lldikti2.id.conf with version 0.31.0 of Certbot. This might not work.
can you help me
Definitely not an IP block. You have very recent libraries, which should work without issue.
This is likely either a firewall issue on your end, or something messed up your server.
These seem to conflict:
do you have a solution?
Do you have multiple versions of certbot installed?
If so, remove all except the latest one.
yes, from ISPConfig and manual via apt. From this i am have done to uninstall from apt, and running from ISPConfig error is the same.
Case close with config
--server https://api.buypass.com/acme/directory
I don't now what happed with
