Unauthorized after running sudocertbot --apache
My domain is: www.learninggardenmontessori.ph
It produced this output: IMPORTANT NOTES:
My web server is (include version): Apache 2.49
The operating system my web server runs on is (include version): Ubuntu Desktop 18.04 Bionic
My hosting provider, if applicable, is: self-serve - domain is provided by www.dotph
I can login to a root shell on my machine (yes or no, or I don’t know): YES
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): NO
Hi @42force
checking your website via learninggardenmontessori.ph - Make your website better - DNS, redirects, mixed content, certificates it looks ok.
http://www.learninggardenmontessori.ph/
122.3.47.190 200 0.833 H
https://www.learninggardenmontessori.ph/
122.3.47.190 -14 10.030 T
Timeout - The operation has timed out
http://www.learninggardenmontessori.ph/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
122.3.47.190 404 0.553 A
Not Foun
Port 80 is open, that's good. Checking the not existing file under /.well-known/acme-challenge there is the good http status 404.
So try to find your DocumentRoot in your VirtualHost of that domain.
Then use
certbot run -a webroot -i apache -w yourDocumentRoot -d www.learninggardenmontessori.ph
to create a new certificate.
Thank you for your response, I will do this and update you!
Which version of certbot are you using?
What does the vhost config file look like?
Thank you for your response, I have use the very recent one
I will send a screen print, but it looks like I was able to install it last night,
although it gave me a different error this time.
Thanks,
We were unable to install your certificate, however, we
successfully restored your server to its prior configuration.
    /etc/letsencrypt/live/learninggardenmontessori.ph/fullchain.pem
I guess I have managed to install it however, it is giving me a confusing message.
"We were unable to install your certificate, however, we
*I am not sure if it was installed or not.
Prior to this error message : there was an error message that I think not related to letsencrypt error,
but just for your reference; I will include the message here
Error while running apache2ctl configtest.
Action ‘configtest’ failed.
AH00526: Syntax error on line 51 of /etc/apache2/sites-enabled/learninggardenmontessori.ph.conf:
Name duplicates previous WSGI daemon definition.
Rolling back to previous server configuration…
The certificate is created, but not installed.
You have to fix that error. What's the content of this file?
If this is fixed, try to use
certbot --reinstall
or
certbot --reinstall --cert-name
--cert-name is listet via certbot certificates
Thank you for your response:
The line 51 shows this line : WSGIDaemonProcess lgms python-path=/home/lgms/testproject/beta/lgms python-home=
however this is need to run the wsgi for django application, I am trying to figure things out if I comment this first and run the certbot as suggested by StackOverFlow.
I appreciate the quick response.
BR,
I have managed to installed it properly finally got this happy message
    /etc/letsencrypt/live/www.learninggardenmontessori.ph/fullchain.pem
    /etc/letsencrypt/live/www.learninggardenmontessori.ph/privkey.pem
    Your cert will expire on 2019-05-06. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
What i did was commented the WSGI comment and it worked.
Thank you so much for your help, I will ask the client for a donation on this.
BR,
