certbot --standalone certonly --cert-name balliu.tech -d balliu.tech -d git.balliu.tech -d jenkins.balliu.tech
You are updating certificate balliu.tech to include new domain(s):
+ jenkins.balliu.tech
You are also removing previously included domain(s):
(None)
Did you intend to make this change?
(U)pdate cert/(C)ancel: U
http-01 challenge for balliu.tech
http-01 challenge for git.balliu.tech
http-01 challenge for jenkins.balliu.tech
Failed authorization procedure. jenkins.balliu.tech (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://jenkins.balliu.tech/.well-known/acme-challenge/EpI9UC4ZKYJH8HITvFcYuoMO3AF49ePe-lkgO0pZnG8: "<html>\r\n<head><title>404 Not Found</title></head>\r\n<body bgcolor=\"white\">\r\n<center><h1>404 Not Found</h1></center>\r\n<hr><center>"
Domain: jenkins.balliu.tech
Detail: Invalid response from
nginx version: nginx/1.14.0
FreeNAS 11.2 jail (FreeBSD 11.2)
Home server
Yes
No
Nginx Config:
#user nobody;
worker_processes 1;
# This default error log path is compiled-in to make sure configuration parsing
# errors are logged somewhere, especially during unattended boot when stderr
# isn't normally logged anywhere. This path will be touched on every nginx
# start regardless of error log location configured here. See
# https://trac.nginx.org/nginx/ticket/147 for more info.
#pid logs/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for"';
access_log logs/access.log main;
sendfile on;
#tcp_nopush on;
#keepalive_timeout 0;
keepalive_timeout 65;
#gzip on;
listen 80 default_server;
server_name _;
listen 443 ssl;
server_name git.balliu.tech;
include ssl_common.conf;
proxy_pass http://192.168.1.199:3000;
include basic_proxy_directives.conf;
# server {
# listen 443 ssl;
# server_name jenkins.balliu.tech;
# include ssl_common.conf;
# location / {
# proxy_pass http://192.168.1.205:8180;
# include basic_proxy_directives.conf;
# proxy_redirect http://192.168.1.205:8180 https://jenkins.balliu.tech;
listen 443 ssl;
proxy_set_header Host $host:$server_port;
# Required for new HTTP-based CLI
proxy_http_version 1.1;
proxy_request_buffering off;
proxy_buffering off; # Required for HTTP-based CLI to work over SSL
# workaround for https://issues.jenkins-ci.org/browse/JENKINS-45651
add_header 'X-SSH-Endpoint' 'jenkins.balliu.tech:50022' always;
ssl_common.conf (referenced in nginx.conf):
# Thanks to https://cipherli.st/ for providing a great reference! Please check out their site
# to make sure your SSL Configuration is up to date with current standards! Be aware that in this
# example we use a slightly liberal cipherlist to allow for older browsers on older devices, Eg.
# IE8, android 2.4, etc
# Enable Perfect Forward Secrecy (PFS)
ssl_prefer_server_ciphers on;
ssl_certificate /usr/local/etc/letsencrypt/live/balliu.tech/fullchain.pem;
ssl_certificate_key /usr/local/etc/letsencrypt/live/balliu.tech/privkey.pem;
# Disable SSLv2 and SSLv3 (BEAST and POODLE attacks)
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
# Enable our strong DH Key
ssl_dhparam /usr/local/etc/ssl/dhparams.pem;
# Cipher-list for PFS.
ssl_ciphers
"EECDH+AESGCM:EDH+AESGCM:ECDHE-RSA-AES128-GCM-SHA256:AES256+EECDH:DHE-RSA-AES128-GCM-SHA256:AES256+EDH:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_ecdh_curve secp384r1;
# Requires nginx >= 1.1.0
ssl_session_cache shared:SSL:10m;
ssl_session_tickets off;
# Requires nginx >= 1.5.9
ssl_stapling on;
# Requires nginx >= 1.3.7
ssl_stapling_verify on;
# Requires nginx => 1.3.7
resolver 8.8.8.8 4.4.4.4 valid=300s;
resolver_timeout 5s;
# HSTS Support
add_header Strict-Transport-Security "max-age=63072000;includeSubdomains; preload";
# These headers can break applications, be careful!
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
I have followed the guide to get ssl on Jenkins inside a jail in Jenkins official wiki:
https://wiki.jenkins.io/display/JENKINS/Running+Jenkins+behind+Nginx
For Nginx:
I have tried everything and cannot get it to work. I feel like I am missing something.
I set up Gitea on https://git.balliu.tech super fast, however Jenkins is being troublesome.
Something I suspect to be the issue is the webroot not being in the same jail and Nginx not having permissions to it. But Gitea is in a different jail too and that worked
If someone could guide me I would greatly appreciate it. Even ideas are fine. At this point I just need another pair of eyes on this stuff.
Thank you!
