Unable to verify first certificate using sun java system application server
*.pontevix.co
certbot certonly \
  --non-interactive \
  --agree-tos \
  --email omar.sa..... \
  --preferred-challenges dns \
  --authenticator dns-porkbun \
  --dns-porkbun-key <my-porkbun-api-key> \
  --dns-porkbun-secret <myporkbun-api-secret> \
  --dns-porkbun-propagation-seconds 60 \
  --key-type rsa
  -d "*.pontevix.co"
This was awhile ago so not sure what to add here. the certificates were generated on the webserver for pontevix.co, but my api is hosted on a different server using a java application (https java sun server) on specific port that is accessible at play.pontevix.co.
pontevix@localhost:~$ sudo certbot certificates
Found the following certs:
Certificate Name: pontevix.co
Serial Number: .........
Key Type: RSA
Domains: *.pontevix.co pontevix.co
Expiry Date: 2023-11-14 00:48:51+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/pontevix.co/fullchain.pem
Private Key Path: /etc/letsencrypt/live/pontevix.co/privkey.pem
Ubuntu 20 (Webserver)
java 17, package com.sun.net.httpserver (API Server)
Linode (Webserver)
Novonode (API Server)
yes (Webserver)
no (API Server)
The only thing I have access to are ports that I can open publicly
The certificates were generated on the webserver
certbot 2.6.0
This is what I am not understanding. The API is reachable on chrome, but not through a python request coming from the webserver. postman is another place it is not working. this page should be reachable with a simple get request.
python version 3.9.16
certifi 2023.5.7
More Information:
I have tried fullchain.pem and cert.pem as my certificate with no luck. private key is privkey.pem
I can show the java code if requested
I can explain a little of what you see but I don't know java server coding well enough to advise. You might be better off asking on a programming forum.
But, as for why Chrome works and others fail ...
Your Java server is only sending a leaf certificate.
Chrome has likely seen and cached the intermediate so can authenticate the cert. Browsers work very hard to adapt to wrongly configured servers.
You can see the "raw" cert your server sends with a tool like below.
If using the java keystore make sure you converted the fullchain.pem properly
You should probably use the fullchain.pem instead of just the cert.pem and then check the chain being served as @MikeMcQ has suggested.
Different apps can trust different chains, this is because some things use their own "trust store" of CA certificates they trust, and they also have different rules as to what to trust.
The default chain acquired by certbot is usually the expired DST Root CA X3 (which going away eventually but was retained mainly for old Android compatibility) and you can force it to try to use the modern chain by setting the certbot --preferred-chain option to "ISRG Root X1" and re-requesting your certificate.
ran the following command
pontevix@localhost:~$ sudo certbot renew --cert-name pontevix.co --force-renewal --preferred-chain "ISRG Root X1"
Processing /etc/letsencrypt/renewal/pontevix.co.conf
Renewing an existing certificate for *.pontevix.co and pontevix.co
Hook 'deploy-hook' ran with output:
 Performing upload action
 Updated file: /etc/letsencrypt/live/pontevix.co/privkey.pem
 Updated file: /etc/letsencrypt/live/pontevix.co/chain.pem
 Updated file: /etc/letsencrypt/live/pontevix.co/cert.pem
 Updated file: /etc/letsencrypt/live/pontevix.co/README
 Updated file: /etc/letsencrypt/live/pontevix.co/fullchain.pem
Congratulations, all renewals succeeded:
  /etc/letsencrypt/live/pontevix.co/fullchain.pem (success)
After this ran, I updated the java server to use fullchain.pem
the tool above was run on my server (https://decoder.link/sslchecker/play.pontevix.co/25572) and I see an error saying "The chain doesn't contain any intermediate certificates".
Both answers were super helpful, and in my case the issue was with my java code. After reviewing my code to create the key store I noticed I was only adding the first certificate from the chain to my store. after some modification it now adds all the cert files.
