My domain is: ivcappservers.com
Processing /etc/letsencrypt/renewal/ivcappservers.com.conf
File "/usr/lib/python3/dist-packages/certbot/_internal/renewal.py", line 71, in _reconstitute
renewal_candidate = storage.RenewableCert(full_path, config)
File "/usr/lib/python3/dist-packages/certbot/_internal/storage.py", line 471, in init
self._check_symlinks()
File "/usr/lib/python3/dist-packages/certbot/_internal/storage.py", line 537, in _check_symlinks
raise errors.CertStorageError(
certbot.errors.CertStorageError: expected /etc/letsencrypt/live/ivcappservers.com/cert.pem to be a symlink
Renewal configuration file /etc/letsencrypt/renewal/ivcappservers.com.conf is broken. Skipping.
No renewals were attempted.
Additionally, the following renewal configurations were invalid:
/etc/letsencrypt/renewal/ivcappservers.com.conf (parsefail)
0 renew failure(s), 1 parse failure(s)
Additional Info: I manually got the certs by installing certbot inside the nginx container, and having volumes to make sure they persisted beyond the container. For whatever reason the symbolic links are not there.
Output of certbot update_symlinks: Saving debug log to /var/log/letsencrypt/letsencrypt.log
Expected /etc/letsencrypt/live/ivcappservers.com/cert.pem to be a symlink
My web server is (include version): Nginx(nginx:latest)
The operating system my web server runs on is (include version): Ubuntu 20.04, using Docker
My hosting provider, if applicable, is: Linode
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
Two questions:
- Is there a way to accomplish this without the symbolic links?
- If not, is there a way to do this using just the certs, or do I have to just request certs all over again?
Color me lost and confused
