Unable to establish SSL connection
My domain is:yppgi.org
I ran this command: wget http://192.168.99.101/ -O -
It produced this output: ```pre
Connecting to 192.168.99.101:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
--2021-03-18 07:13:19-- https://192.168.99.101/
Connecting to 192.168.99.101:443... connected.
OpenSSL: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu) and Apache/2.4.41 (Ubuntu)
The operating system my web server runs on is (include version): UBUNTU 18.0.4 LTS
My hosting provider, if applicable, is: none
The version of my client is (e.g. output of `certbot --version` or `certbot-auto --version` if you're using Certbot): certbot 0.31.0
I don't really know what happened to my website. It's been running for more than 7 months. Nothing configured whatsoever since, then suddenly my website stopped working. I can't open my website. It says " This site can’t provide a secure connection".
since it's about secure connection, I thought that it might be the SSL. I tried to restart my apache service webserver and nginx as well. but it does nothing.
All 443 ports on both apache and nginx are opened. the services are allowed too on UFW. FULL APACHE and FULL NGINX.
Here's my virtual host config on apache:
```pre <VirtualHost *:443>
    ServerName YPPGI.org
    ServerAlias www.YPPGI.org
    ServerAdmin webmaster@YPPGI.org
    DocumentRoot /var/www/YPPGI
    SetEnvIf X-Forwarded-Proto "https" HTTPS=on
</VirtualHost>
<VirtualHost *:80>
</VirtualHost> ```
And this is for NGINX:
```pre
  listen 443 ssl;
  ssl on;
  ssl_certificate /etc/letsencrypt/live/yppgi.org/fullchain.pem; # managed by Certbot
  ssl_certificate_key /etc/letsencrypt/live/yppgi.org/privkey.pem; # managed by Certbot
  include /etc/letsencrypt/options-ssl-nginx.conf;
  ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
    proxy_pass http://192.168.99.101;
    proxy_http_version 1.1;
    proxy_set_header Connection 'upgrade';
    proxy_set_header Host $host;
    proxy_cache_bypass $http_upgrade;
    proxy_redirect off;
    proxy_set_header X-Forwarded-Ssl $scheme;
 listen 80;
 server_name yppgi.org www.yppgi.org;
 return 310 https://$host$request_uri;
Hi @MarioYoku
you have to use your domain name, not a private ip address.
wget http://yppgi.org/ -O -
output: pre http://yppgi.org/ Resolving yppgi.org (yppgi.org)... 36.95.54.193 Connecting to yppgi.org (yppgi.org)|36.95.54.193|:80...
wget https://yppgi.org/ -O -
Connecting to yppgi.org (yppgi.org)|36.95.54.193|:443...```
Anyone can help ?
Now whenever I open my website , it says " The webpage at http://yppgi.org/ might be temporarily down or it may have moved permanently to a new web address."
Is it my routing or my virtual host config ? If I ping my dns. it's working but can't open the dns on browser. It seems like it's not pointing to my DNS.
Your network is buggy. Please change that.
That's not a Letsencrypt relevant question.
