Unable to configure two -way-ssl for mariadb using letsencrypt certificate
I am using centos 7 and trying to configure mariadb two way ssl. I have generated certificate for mariadbserver and mariadbuser using certbot
My domain is: mariadbserver and mariadbuser
Sudo certbot certonly -d mariadbserver -d mariadb user
It produced this output: chain.pem cert.pem fullchain.pem privkey.pem
For both client and server.i moved all these files to /etc/my.cnf.d/certificates ,I renamed it for client and server after renaming my certificate folder looks like
Client-cert.pem client-chain.pem client-fullchain.pem client-privkey.pem server-chain.pem server-cert.pem server-fullchain.pem server-privkey.pem
For the certificate folder i have given sudo chown -R mysql. /etc/my.cnf.d/certificates
Then in /etc/my.cnf file i added below configuration
[Client-Mariadb]
Ssl-ca=/etc/my.cnf.d/certificates/client-chain.pem
Ssl-cert=/etc/my.cnf.d/certificates/client-cert.pem
Ssl-key=/etc/my.cnf.d/certificates/client-privkey.pem
[mariadb]
Ssl-ca=/etc/my.cnf.d/certificates/server-chain.pem
Ssl-cert=/etc/my.cnf.d/certificates/server-cert.pem
Ssl-key=/etc/my.cnf.d/certificates/server-privkey.pem
Then i restarter mariadb server but after login to mariadb terminal status is showning cipher is not in use. What is the problem? Please help
I can login to a root shell on my machine (yes or no) : yes
[Hi @Dev, and welcome to the LE community forum :slight_smile:
If you were able to obtain an LE cert, then there is little more that we can do for you.
[possibly help with the autorenewal process of any LE certs]
For your described problem, I would start here:
SHOW VARIABLES LIKE 'have_ssl';
So what are/is the domain? This can be configured but there has TO BE A FQDN.
Am I missing something? Probably. How can someone get a cert for mariadbserver and mariadbuser... something is missing here. I cant imagine LE issuing any certs for a non FQDN.
More info needed.
RIP
Hello @Dev, welcome to the Let's Encrypt community. :slightly_smiling_face:
I realize that progress has been made on your issue, however it is still would likely be helpful to answer the questionnaire below.
Thank you for assisting us in helping YOU!
