{ "type": "urn:ietf:params:acme:error:malformed", "detail": "Method not allowed", "status": 405 }
I am trying to create a certificate, but I ran into the following error while trying to create a Cluster Issuer.
"status": 405
I used the following commands
$ helm install cert-manager jetstack/cert-manager --namespace cert-manager-new --version v1.3.0 --set installCRDs=true
apiVersion: cert-manager.io/v1
kind: ClusterIssuer
metadata:
spec:
  acme:
    email: mmadiawetsa@yahoo.com
    server: https://acme-staging-v02.api.letsencrypt.org/directory
    privateKeySecretRef:
    solvers:
    - http01:
        ingress:
          class: nginx
$ kubectl apply -f .yaml
helm 3.5.2
Kubernetes EKS 1.16
cert-manager 1.3.0
I'm not familiar with that specific tool, but that type of error would generally indicate a bug in the ACME client not sending a correct request to Let's Encrypt's servers. (Or perhaps, some misconfiguration that's not checked for or reported well, that then leads to it sending bad requests later in the process.)
It's possible somebody else here can point you in the right direction, but you might also want to check if there's some cert-manager specific support options available as well.
Potentially related: my orders keeping returning 405 · Issue #2954 · jetstack/cert-manager · GitHub
