I put 4 of them, let me knĂ w if needs all, look like some use installer some not, not sure what i did here, can i make it all the same renwal way so it will be easier? Also i see # renew_before_expiry = 30 days does it mean if i uncomment it it will renew automatically? (up to now i do manually every 3 months)
www.sign-art.app
version = 0.40.0
archive_dir = /etc/letsencrypt/archive/www.sign-art.app
cert = /etc/letsencrypt/live/www.sign-art.app/cert.pem
privkey = /etc/letsencrypt/live/www.sign-art.app/privkey.pem
chain = /etc/letsencrypt/live/www.sign-art.app/chain.pem
fullchain = /etc/letsencrypt/live/www.sign-art.app/fullchain.pem
[renewalparams]
account = fd7f3c9aafe669c533299cd899585305
authenticator = nginx
installer = nginx
apitest.sign-art.app
version = 0.40.0
archive_dir = /etc/letsencrypt/archive/apitest.sign-art.app
cert = /etc/letsencrypt/live/apitest.sign-art.app/cert.pem
privkey = /etc/letsencrypt/live/apitest.sign-art.app/privkey.pem
chain = /etc/letsencrypt/live/apitest.sign-art.app/chain.pem
fullchain = /etc/letsencrypt/live/apitest.sign-art.app/fullchain.pem
[renewalparams]
installer = nginx
api.sign-art.app
version = 0.40.0
archive_dir = /etc/letsencrypt/archive/api.sign-art.app
cert = /etc/letsencrypt/live/api.sign-art.app/cert.pem
privkey = /etc/letsencrypt/live/api.sign-art.app/privkey.pem
chain = /etc/letsencrypt/live/api.sign-art.app/chain.pem
fullchain = /etc/letsencrypt/live/api.sign-art.app/fullchain.pem
[renewalparams]
[renewalparams]
installer = nginx
I don't see how that makes things any easier.
Automating the entire process makes it easier.
Piling all your certs to renew at the exact same time actually creates an unnecessary traffic jam - LOL
30 days is the default; So commented or not the result is the same.
That line has nothing to do with if it renews automatically or not.
That whole config is used whenever a renewal is attempted.
How renewals are triggered is through scheduled tasks (cron jobs or systemd timers).
Ok i see, thanks a lot for doing all this, really huge help.
Here the result after certbot renew --dry-run -v:
Domain: alpha.sign-art.app
Detail: Invalid response from
https://alpha.sign-art.app/.well-known/acme-challenge/FAX8bVrE_BeMB8Pqyorfzo1u0y7LkPugK8sc_ZOaPYY
[2606:4700:3034::ac43:d83f]: "<!DOCTYPE html><html prefix=\"og:
http://ogp.me/ns#\"><head><meta charset=UTF-8><meta name=viewport
content=\"width=device-width,in"
Domain: api.sign-art.app
https://api.sign-art.app/.well-known/acme-challenge/7yXJhEHsUgecHbmtytKO4yF06XIzwLy8BuJEWsT1xng
[2606:4700:3032::6815:10db]: "<html>\n<head><title>404 Not
Found</title></head>\n<body>\n<center><h1>404 Not
Found</h1></center>\n<hr><center>nginx/1.17.10 (Ubunt"
Domain: apitest.sign-art.app
https://apitest.sign-art.app/.well-known/acme-challenge/gPcrsfAC6-9unYRy74vEQ684rW7VFDcdLfreX40cFA0
[2606:4700:3034::ac43:d83f]: "<html>\n<head><title>404 Not
Domain: beta.sign-art.app
https://beta.sign-art.app/.well-known/acme-challenge/wgZ5QIMMjzjNcL7a8222GPBfR10U9iOzd5iwmyTTOsg
Domain: faucet.sign-art.app
https://faucet.sign-art.app/.well-known/acme-challenge/xgN8zkeRPWxab1lEERgOV71fgbRXmiflfOMS_Hi-crk
Domain: mainnet.sign-art.app
https://mainnet.sign-art.app/.well-known/acme-challenge/qZNzRIRAWdWbLtRDwkb4dSpSHo2zQ6ii77y4SMbIQIk
Domain: preprod.sign-art.app
http://preprod.sign-art.app/.well-known/acme-challenge/dY3ygAPWzI4fbdIx13Yz8dLiEZpM07gNsw_IQ4DErIk
[2606:4700:3032::6815:10db]: "<!DOCTYPE html>\n<!--[if lt IE 7]>
<html class=\"no-js ie6 oldie\" lang=\"en-US\">
<![endif]-->\n<!--[if IE 7]> <html class=\"no-js "
Domain: sign-art.app
https://sign-art.app/.well-known/acme-challenge/q_eZ8XHbnfOyD56PN6r_zTct_RXHiG0kEV_WhbIXDVk
Domain: www.sign-art.app
https://www.sign-art.app/.well-known/acme-challenge/LuA6eW9kameshxwvlh3bOaRpH2Z3NFnPHHx5Flf_EQk
https://sign-art.app/.well-known/acme-challenge/wIdVtV4u1mDjOcBxMhOBcBVTUx9j0nwXX8K_P0vN82g
Domain: site.sign-art.app
https://site.sign-art.app/.well-known/acme-challenge/JXaqianEn8hHC5aiQgAypW9QmeRErCsUFRbz6MmVQGM
https://www.sign-art.app/.well-known/acme-challenge/vcHOUjJtpHdpwpXB-P1DkSksVpUnN678EfUAQPqcHEw
If certbot runs on this box, yes.
You might be able to put it in the well-known location block.
Re-re-reviewing the whole config, it is now obvious: that is the main difference.
The ones that work all have roots.
The ones without roots (using proxy) are all failing (or going to fail on next renewal attempt).
The trick it to do both:
provide a local root path for the HTTP challenge files to be served from
That may not be a good secure location.
[unless that directory is empty or has nothing critical stored there - or further down that path]
It is highly recommended that you create a new and dedicated challenge path.
No.
I'm only talking about how to properly/securely handle requests like: https://your.domain/.well-known/acme-challenge/test-file-1234
Everything else gets proxied as before.
Ah ok i see, it doesnt have to be the path to my app, just a path to where the well-know test file will be.
So i can do /home/letsencrypt/challenge for example its ok?
