I have a website online which works and has letsencrypt security certificates. I am trying to run it locally.
When I try
I get
Cannot find a VirtualHost matching domain backend.ultimaterehabestimator.com . In order for Certbot to correctly perform the challenge please add a corresponding server_name directive to your nginx configuration: https://nginx.org/en/docs/http/server_names.html
But I have this:
listen 443 ssl;
listen [::]:443 ssl;
server_name backend.ultimaterehabestimator.com ;
ssl_certificate /etc/letsencrypt/live/ultimaterehab.charstarstar.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/ultimaterehab.charstarstar.com/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/ultimaterehab.charstarstar.com/fullchain.pem;
proxy_pass http://127.0.0.1:4567;
in my nginx.conf file (and I restarted it after adding it)
schoen
November 9, 2017, 9:48pm
#2
@erica , would you mind taking a look at this?
schoen
November 9, 2017, 9:52pm
#3
Also, if you’re doing this for local development and testing, could you use a self-signed certificate instead of a new publicly-trusted certificate? This is usually a reasonable option when you’re the only one who will access the server. (For “realism”, you could even choose to save the self-signed certificate in the same path where the Let’s Encrypt certificate goes on the production server.)
Thanks for the reply.
I’m using something called ngrok which allows me to easily put locally running websites online.
erica
November 10, 2017, 12:05am
#5
Would you mind posting:
the entire contents of your nginx.conf
file
the results of tree /etc/nginx/
the results of nginx -t
Also, I don’t know how ngrok works, but I’d honestly be surprised if it works with Certbot out of the box, because Certbot is designed to run on the server that’s hosting the site.
If I can’t use Certbot I can use digital ocean (but I’m not sure if just an IP would work).
nginx -t fails unless I use sudo, it gives me:
here is the tree:
/etc/nginx/
├── conf.d
├── fastcgi.conf
├── fastcgi_params
├── koi-utf
├── koi-win
├── mime.types
├── modules-available
├── modules-enabled
│ ├── 50-mod-http-geoip.conf -> /usr/share/nginx/modules-available/mod-http-geoip.conf
│ ├── 50-mod-http-image-filter.conf -> /usr/share/nginx/modules-available/mod-http-image-filter.conf
│ ├── 50-mod-http-xslt-filter.conf -> /usr/share/nginx/modules-available/mod-http-xslt-filter.conf
│ ├── 50-mod-mail.conf -> /usr/share/nginx/modules-available/mod-mail.conf
│ └── 50-mod-stream.conf -> /usr/share/nginx/modules-available/mod-stream.conf
├── nginx.conf
├── proxy_params
├── scgi_params
├── sites-available
│ └── default
├── sites-enabled
│ └── default -> /etc/nginx/sites-available/default
├── snippets
│ ├── fastcgi-php.conf
│ ├── self-signed.conf
│ ├── snakeoil.conf
│ └── ssl-params.conf
├── uwsgi_params
└── win-utf
and here’s the file:
user www-data;
worker_processes 3;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
ssl_protocols TLSv1.2;
ssl_ciphers EECDH+AESGCM:EECDH+AES;
ssl_ecdh_curve secp384r1;
ssl_prefer_server_ciphers on;
ssl_stapling on;
ssl_stapling_verify on;
add_header Strict-Transport-Security "max-age=15768000; includeSubdomains; preload";
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
# include /etc/nginx/conf.d/*.conf;
# include /etc/nginx/sites-enabled/*;
listen 80 default_server;
listen [::]:80 default_server ipv6only=on;
server_name domain.com.com;
return 301 https://domain.com$request_uri;
# SSL configuration
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
include snippets/self-signed.conf;
include snippets/ssl-params.conf;
listen 443 ssl;
server_name backend.domain.com.com ;
ssl_certificate /etc/letsencrypt/live/domain.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/domain.com/privkey.pem;
ssl_trusted_certificate /etc/letsencrypt/live/domain.com/fullchain.pem;
listen 5000 ssl;
listen [::]:5000 ssl;
server_name backend.domain.com.com;
listen 444 ssl;
listen [::]:444 ssl;
server_name domain.com;
proxy_pass http://127.0.0.1:5000;
erica
November 14, 2017, 12:30am
#7
So it looks like this server block is the one you’re hoping to install a cert into, is that right? There’s no server-name
directive in this block. Unless you’re trying to get a cert for backend.domain.com
# SSL configuration
system
closed
December 14, 2017, 12:30am
#8
