Trying to get a certificate ends with "Some challenges have failed. Ask for help ..."
When I try to get a LetsEncrypt certificate, the process failes and I tried multiple times and could not find a solution yet. Maybe somebody can help me - thank you very much in advance!
sauerer.mooo.com
sudo certbot --apache
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): sauerer.mooo.com
Requesting a certificate for sauerer.mooo.com
Domain: sauerer.mooo.com
Type: connection
Detail: 2001:a62:6ee:1b01:7d60:5cb6:5bc0:d439: Fetching http://sauerer.mooo.com/.well-known/acme-challenge/fJGTH_oG1ZGT_C8vGey8kh3Bgq-PfM1UF7UXjxuGrkg: Error getting validation data
And the logfile:
sudo tail -n 50 /var/log/letsencrypt/letsencrypt.log
2025-02-18 05:53:46,120:DEBUG:certbot._internal.display.obj:Notifying user:
Type: connection
2025-02-18 05:53:46,121:DEBUG:certbot._internal.error_handler:Encountered exception:
File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 106, in handle_authorizations
File "/usr/lib/python3/dist-packages/certbot/_internal/auth_handler.py", line 206, in _poll_authorizations
2025-02-18 05:53:46,121:DEBUG:certbot._internal.error_handler:Calling registered functions
2025-02-18 05:53:46,121:INFO:certbot._internal.auth_handler:Cleaning up challenges
2025-02-18 05:53:46,300:DEBUG:certbot._internal.log:Exiting abnormally:
File "/usr/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot==2.1.0', 'console_scripts', 'certbot')())
File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1736, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1440, in run
new_lineage = _get_and_save_cert(le_client, config, domains,
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 138, in _get_and_save_cert
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 516, in obtain_and_enroll_certificate
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 428, in obtain_certificate
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 496, in _get_order_and_authorizations
2025-02-18 05:53:46,302:ERROR:certbot._internal.log:Some challenges have failed.
Server version: Apache/2.4.62 (Debian)
Server built: 2024-10-04T15:21:08
Raspberry OS Debian 12.7
None, it's home-hosted behind a FritzBox-Router dnd DDNS
no
certbot 2.1.0
Hi. Before trying to get a certificate, you need to make sure to have your (web)server's port 80 (when using HTTP-01 challenge) is reachable over internet. At the moment your domain lacks any A record, and has an AAAA record. But when trying to connect I get permission denied:
curl -v -6 http://sauerer.mooo.com
* Host sauerer.mooo.com:80 was resolved.
* IPv6: 2001:a62:6ee:1b01:76bf:7c8e:5fcb:26d0
* IPv4: (none)
*   Trying [2001:a62:6ee:1b01:76bf:7c8e:5fcb:26d0]:80...
* connect to 2001:a62:6ee:1b01:76bf:7c8e:5fcb:26d0 port 80 from […] port 60202 failed: Permission denied
* Failed to connect to sauerer.mooo.com port 80 after 152 ms: Could not connect to server
Make sure the IP address is correct and review firewall config.
Hi @Covi,
It seems there is only an IPv6 Address, shouldn't be an issue. Permanent link to this check report
From around the world for HTTP Permanent link to this check report is getting "No such device or address".
From around the world for HTTPS Permanent link to this check report is getting the same results of "No such device or address"
Using the online tool Let's Debug yields these results https://letsdebug.net/sauerer.mooo.com/2369186
