I have been able to create and renew certs from the command line without any problems but I am now wanting to move this to cron. To do this I am running this on the command line as a test before moving to cron:
sudo /home/ec2-user/letsencrypt/letsencrypt-auto --config /home/ec2-user/letsencrypt/cert.ini certonly --debug
&& service httpd reload
Which gives me the following:
Updating letsencrypt and virtual environment dependencies......
Requesting root privileges to run with virtualenv: /root/.local/share/letsencrypt/bin/letsencrypt --config /home/ec2-user/letsencrypt/secure_textinconfidence_com.ini certonly --debug
Version: 1.1-20080819
- Congratulations! Your certificate and chain have been saved at
/etc/letsencrypt/live/secure.textinconfidence.com/fullchain.pem.
Your cert will expire on 2016-05-03. To obtain a new version of the
certificate in the future, simply run Let's Encrypt again.
- If you like Let's Encrypt, please consider supporting our work by:
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Reloading httpd: not reloading due to configuration syntax error
[FAILED]
However when I run:
sudo service httpd configtest
I get:
Syntax OK
Is there something wrong with my command when combining with the cert renewal?
