Trouble with renewing SSL certificate
My domain is: justanotherwhiteguy.com
I ran this command: sudo letsencrypt
No names were found in your configuration files. Please enter in your domain
name(s) (comma and/or space separated) (Enter 'c' to cancel):justanotherwhiteguy.com
tls-sni-01 challenge for justanotherwhiteguy.com
Enabled Apache socache_shmcb module
Enabled Apache ssl module
Failed authorization procedure. justanotherwhiteguy.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 632a85b11faf03cf68b0e4762d2543aa.c16bc814eca60c71c695506525fa1b97.acme.invalid from 24.217.35.240:443. Received 2 certificate(s), first certificate had names "justanotherwhiteguy.com, www.justanotherwhiteguy.com"
Domain: justanotherwhiteguy.com
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
My web server is (include version): Apache/2.4.18 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 16.04.2
Try entering both names (as found in the current cert):
Similar issue
name(s) (comma and/or space separated) (Enter 'c' to cancel):justanotherwhiteguy.com www.justanotherwhiteguy.com
tls-sni-01 challenge for www.justanotherwhiteguy.com
Failed authorization procedure. www.justanotherwhiteguy.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested d784fec99b92921efa81ded5eabc1164.9e63d334c51f096f313f573cbb2dd169.acme.invalid from 24.217.35.240:443. Received 2 certificate(s), first certificate had names "justanotherwhiteguy.com, www.justanotherwhiteguy.com", justanotherwhiteguy.com (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 900867af4fd197fee00e910ab196b2c4.b704b1037d6df441a7c9e26f62980503.acme.invalid from 24.217.35.240:443. Received 2 certificate(s), first certificate had names "justanotherwhiteguy.com, www.justanotherwhiteguy.com"
Domain: www.justanotherwhiteguy.com
Requested
Requested
I think there may be an confusion with your vhost file for that domain and another vhost file (possibly for “default”).
Which may require you to direct the LE to the specific webroot for the domain.
try:
sudo letsencrypt --webroot /local/path/to/site/files
You are absolutely correct. facepalm…:persevere: I recently migrated my website to my new server and my daily driver is now my old server…I was trying to renew the cert on the wrong server.
Just to be clear, the approach that @rg305 proposed uses a completely different validation method (even on a different TCP port) and also does not use an installer, so it wouldn’t be able to restart the web server for you. It may be more likely to work on some systems that encounter this problem, but it’s not a drop-in replacement to perform the same task!
