503 Error after Certificate from Let´s Encrypt
July 12, 2021
Dear Jonathan Griffin!
The issue seems to be script related. If you want to check I will be able to give you access to the server and you will be able to check yourself, please.
The Error Log file from July 12, 2021, sozialepfalz.de
[Mon Jul 12 01:45:20.571297 2021] [proxy:error] [pid 22944] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 01:45:20.571751 2021] [proxy_fcgi:error] [pid 22944] [client 47.91.128.217:44930] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 02:14:07.365548 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 04:27:59.836943 2021] [proxy:error] [pid 28559] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 04:27:59.837703 2021] [proxy_fcgi:error] [pid 28559] [client 158.69.42.164:52536] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 04:49:08.225961 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 04:53:03.614068 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 05:01:04.440385 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 05:06:55.205358 2021] [proxy:error] [pid 6496] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 05:06:55.205415 2021] [proxy_fcgi:error] [pid 6496] [client 34.254.164.69:57384] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 05:29:24.852201 2021] [proxy:error] [pid 7581] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 05:29:24.855711 2021] [proxy_fcgi:error] [pid 7581] [client 40.77.167.50:10880] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 05:29:30.400655 2021] [proxy:error] [pid 6566] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 05:29:30.400690 2021] [proxy_fcgi:error] [pid 6566] [client 40.77.167.99:57600] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 05:42:09.097383 2021] [proxy:error] [pid 7028] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 05:42:09.097440 2021] [proxy_fcgi:error] [pid 7028] [client 5.61.25.2:47814] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 05:42:13.490148 2021] [proxy:error] [pid 7207] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 05:42:13.490202 2021] [proxy_fcgi:error] [pid 7207] [client 5.61.25.2:48324] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 05:42:47.790150 2021] [proxy:error] [pid 7122] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 05:42:47.790202 2021] [proxy_fcgi:error] [pid 7122] [client 209.126.30.101:54743] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 06:57:28.651763 2021] [proxy:error] [pid 10042] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 06:57:28.652402 2021] [proxy_fcgi:error] [pid 10042] [client 13.233.94.89:54595] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 07:16:42.007165 2021] [proxy:error] [pid 11657] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 07:16:42.007573 2021] [proxy_fcgi:error] [pid 11657] [client 114.119.167.129:47714] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 07:32:06.568194 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 07:33:03.932477 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 07:38:03.140817 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 07:39:03.565763 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 07:40:03.708677 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 08:03:33.897236 2021] [proxy:error] [pid 15471] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 08:03:33.897310 2021] [proxy_fcgi:error] [pid 15471] [client 202.39.38.247:51098] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 08:09:26.494604 2021] [proxy:error] [pid 15450] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 08:09:26.494651 2021] [proxy_fcgi:error] [pid 15450] [client 157.55.39.19:14528] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 08:09:27.097735 2021] [proxy:error] [pid 15813] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 08:09:27.097777 2021] [proxy_fcgi:error] [pid 15813] [client 157.55.39.19:14529] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 08:09:50.504398 2021] [proxy:error] [pid 15416] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 08:09:50.504443 2021] [proxy_fcgi:error] [pid 15416] [client 207.46.13.77:34176] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 09:28:06.921237 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 09:42:04.009389 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 09:43:04.071052 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 09:49:03.325566 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 10:05:04.943567 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 10:08:03.331922 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 10:15:34.331395 2021] [proxy:error] [pid 23229] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:15:34.331716 2021] [proxy_fcgi:error] [pid 23229] [client 114.119.152.8:13930] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 10:27:13.372788 2021] [proxy:error] [pid 23979] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:27:13.372877 2021] [proxy_fcgi:error] [pid 23979] [client 151.106.117.82:39512] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 10:30:38.276734 2021] [proxy:error] [pid 23229] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:30:38.276781 2021] [proxy_fcgi:error] [pid 23229] [client 199.16.157.181:45692] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 10:30:38.496506 2021] [proxy:error] [pid 23972] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:30:38.496558 2021] [proxy_fcgi:error] [pid 23972] [client 199.16.157.181:45716] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 10:30:38.718605 2021] [proxy:error] [pid 23261] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:30:38.718648 2021] [proxy_fcgi:error] [pid 23261] [client 199.16.157.181:64042] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 10:30:38.953925 2021] [proxy:error] [pid 23909] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:30:38.953957 2021] [proxy_fcgi:error] [pid 23909] [client 199.16.157.181:41619] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 10:30:39.219459 2021] [proxy:error] [pid 23248] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 10:30:39.219516 2021] [proxy_fcgi:error] [pid 23248] [client 199.16.157.181:55554] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 10:45:07.475266 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 10:56:03.871287 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 10:57:03.864335 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:07:04.724240 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:14:05.552565 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:20:48.593409 2021] [proxy:error] [pid 31197] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 11:20:48.593455 2021] [proxy_fcgi:error] [pid 31197] [client 91.66.170.243:63623] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 11:20:48.969086 2021] [proxy:error] [pid 31044] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 11:20:48.969135 2021] [proxy_fcgi:error] [pid 31044] [client 91.66.170.243:55164] AH01079: failed to make connection to backend: httpd-UDS, referer: http://sozialepfalz.de/
[Mon Jul 12 11:21:05.668266 2021] [proxy:error] [pid 31207] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 11:21:05.668344 2021] [proxy_fcgi:error] [pid 31207] [client 91.66.170.243:62441] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 11:21:06.113864 2021] [proxy:error] [pid 31034] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 11:21:06.113917 2021] [proxy_fcgi:error] [pid 31034] [client 91.66.170.243:61815] AH01079: failed to make connection to backend: httpd-UDS, referer: http://sozialepfalz.de/
[Mon Jul 12 11:27:04.237412 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:28:03.321606 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:30:03.642524 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:31:04.111093 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:36:03.349165 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:44:03.910120 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 11:47:12.000293 2021] [proxy:error] [pid 2534] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 11:47:12.000360 2021] [proxy_fcgi:error] [pid 2534] [client 114.119.135.64:46446] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 12:08:59.228700 2021] [proxy:error] [pid 3639] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 12:08:59.228787 2021] [proxy_fcgi:error] [pid 3639] [client 103.148.245.19:53603] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 12:16:04.977098 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 12:37:04.099557 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 13:07:02.057091 2021] [proxy:error] [pid 7072] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 13:07:02.057164 2021] [proxy_fcgi:error] [pid 7072] [client 34.254.202.59:40972] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 13:11:19.855750 2021] [proxy:error] [pid 7815] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 13:11:19.856086 2021] [proxy_fcgi:error] [pid 7815] [client 103.148.245.19:55474] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 13:17:06.708306 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 13:20:04.277642 2021] [ssl:warn] [pid 28634] AH01909: www.sozialepfalz.de:443:0 server certificate does NOT include an ID which matches the server name
[Mon Jul 12 13:24:15.275831 2021] [proxy:error] [pid 9467] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 13:24:15.275869 2021] [proxy_fcgi:error] [pid 9467] [client 148.70.125.137:52132] AH01079: failed to make connection to backend: httpd-UDS, referer: http://simplesite.com
[Mon Jul 12 13:33:00.388160 2021] [proxy:error] [pid 9446] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 13:33:00.388235 2021] [proxy_fcgi:error] [pid 9446] [client 114.119.149.159:38202] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 13:51:06.582871 2021] [proxy:error] [pid 10533] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 13:51:06.582922 2021] [proxy_fcgi:error] [pid 10533] [client 91.66.170.243:52406] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 13:51:06.756543 2021] [proxy:error] [pid 9610] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 13:51:06.756609 2021] [proxy_fcgi:error] [pid 9610] [client 91.66.170.243:60853] AH01079: failed to make connection to backend: httpd-UDS, referer: http://sozialepfalz.de/
[Mon Jul 12 14:07:16.268022 2021] [proxy:error] [pid 11217] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 14:07:16.268114 2021] [proxy_fcgi:error] [pid 11217] [client 91.66.170.243:52769] AH01079: failed to make connection to backend: httpd-UDS
[Mon Jul 12 14:07:16.412199 2021] [proxy:error] [pid 9603] (2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /usr/local/php74/sockets/andreasd.sock (*) failed
[Mon Jul 12 14:07:16.412245 2021] [proxy_fcgi:error] [pid 9603] [client 91.66.170.243:50192] AH01079: failed to make connection to backend: httpd-UDS, referer: http://sozialepfalz.de/
Thank you in advance.
Kind regards,
Andreas Klamm (Andreas Klamm Sabaot), Senator h. c. of Conch Republic, Fürst von Liechtenstein-Kastelkorn, Graf von Wolf zu Wolfsthal, Journalist, Rundfunk-Journalist, Reporter, Autor, staatl. geprft. Gesundheits- und Krankenpfleger, Musik- und Medienproduzent, oterapro Radio Fernsehen Nachrichten Medien und Informationen, Kommunikations- und Nachrichten-Dienste, Radio TV IBS Liberty, Regionalhilfe.de, ISMOT International Social And Medical Outreach Team.
Journalisten-Bureau Andreas Klamm-Sabaot, Andreas Klamm Journalist, Schillerstr. 31, D 67141 Neuhofen in der Pfalz, Verbandsgemeinde Rheinauen, Rhein-Pfalz-Kreis, Rheinland-Pfalz, Deutschland, Tel. 0621 4909 650 117, Tel. 0621 5867 8054, Tel. 030 57 700 592, Mobil-Tel. 01579 232 0437, (Germany Telephone Country Code 0049, GER / DE). www.andreasklamm.de und www.andreaspklamm.de
