Hello, I've had my setup running for 2 years. Now my domain provider started charging extra for DNS features which made me swap to Cloudflare. Then things broke and I forgot how I setup everything, hopefully I can get some help. Im running traefik for reverse proxys for my docker containers(homeassistant/plex/etc).
My first thought was that SSL was broken from the nameserver change, I could access domain.com but it complained about certificate somehow. I followed the basic guide and tried sudo certbot certonly --webroot first for siljedahls.se without success. Port 443 from Traefik was in conflict at first. a SSL checker also says that there is "Certificate name mismatch", possibly a conflict with Traefik somehow? Sorry for this confusing report, I am very noob and I want to provide as much details as possible
My domain is: siljedahls.se
I ran this command: certbot -d siljedahls.se -d www.siljedahls.se
Error while running apache2ctl configtest.
Action 'configtest' failed.
AH00526: Syntax error on line 35 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/www.siljedahls.se/fullchain.pem' does not exist or is empty
The operating system my web server runs on is (include version): Ubuntu 19.04
or certbot-auto --version
if you're using Certbot): 1.22.0
