Hello,
My IT specialist has done several installations of Magento and he made several certificate requests, after he deleted the virtuel machine to redo a clean installation but he hangs with:
Too many certificates already issued for exact set of domains
Is there a way to delete old certificates please.
Thank you so much.
No, it is not possible to delete production certificates from the certificate transparency logs. To continue the test of redoing the virtual machine, I suggest to configure the ACME client to use staging certificate. There is no rate limit there.
There is, and you (or your "specialist") have already done that. But that doesn't restore the resources used to create them. This is why the staging environment exists, but it seems people don't learn about that until they've hit the limit.
You can, but you almost always shouldn't. Revoking a certificate does not remove it from existence. Revocation only causes the CA to indicate that the certificate was revoked when an inquiry is made regarding the certificate.
You probably can, but that doesn't affect the rate limits--again, the resources required to create the certs have already been expended; revoking them doesn't change that.
You should really read limitations... anyway there is way around it, i see you only issued cert for hb-plomberie-chauffage.fr, just add additional sub domain or wildcard...
