Too many certificates already issued for exact set of domains
My domain is: docportal.abfr.be
I ran this command:de.midpoints.le4d.manager.Le4dManager.orderCertificateUseHTTPChallenge(Le4dManager.java:181)
I had issues in the beginning with the tool and had too many attempts. The tool works now but I’m unable to request a new certificate.
It produced this output: org.shredzone.acme4j.exception.AcmeRateLimitedException: Error creating new order :: too many certificates already issued for exact set of domains: docportal.abfr.be
My web server is (include version): Domino 10.0.1FP2
The operating system my web server runs on is (include version): CentOS 7
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): I’m using a tool on Domino, https://www.midpoints.de/en-solutions-LE4D
Hi @debisschopk
there is a check of your domain, ~~45 minutes old - https://check-your-website.server-daten.de/?q=docportal.abfr.be#ct-logs
Let's Encrypt Authority X3 2019-09-27 2019-12-26 docportal.abfr.be - 1 entries duplicate nr. 5 next Letsencrypt certificate: 2019-10-04 11:17:51
Let's Encrypt Authority X3 2019-09-27 2019-12-26 docportal.abfr.be - 1 entries duplicate nr. 4
Let's Encrypt Authority X3 2019-09-27 2019-12-26 docportal.abfr.be - 1 entries duplicate nr. 3
Let's Encrypt Authority X3 2019-09-27 2019-12-26 docportal.abfr.be - 1 entries duplicate nr. 2
Let's Encrypt Authority X3 2019-09-27 2019-12-26 docportal.abfr.be - 1 entries duplicate nr. 1
5 identical certificates, that hits the limit.
Please read
Where are these certificates? Use one.
Hello
I don’t have the files anymore, can I get them somewhere on the site ?
That's bad. You can download the public part, but without the private key that doesn't help.
Then you have to wait. Or add another domain / subdomain as described ( https://letsencrypt.org/docs/rate-limits/ ).
when I look at the first entry in the list, does it mean that as of the 4th of october I can retry ?
Yes, that's correct. 7 * 24 hours after your first blocking entry.
