time="2024-06-05T08:25:31Z" level=error msg="Unable to obtain ACME certificate for domains \"immich.hendrikthues.com\": unable to generate a certificate for the domains [immich.hendrikthues.com]: error: one or more domains had a problem:\n[immich.hendrikthues.com] acme: error: 400 :: urn:ietf:params:acme:error:tls :: 81.169.145.70: remote error: tls: handshake failure\n" ACME CA="https://acme-v02.api.letsencrypt.org/directory" providerName=le.acme routerName=immich@docker rule="Host(`immich.hendrikthues.com`)"
time="2024-06-05T08:25:32Z" level=error msg="Unable to obtain ACME certificate for domains \"hass.hendrikthues.com\": unable to generate a certificate for the domains [hass.hendrikthues.com]: error: one or more domains had a problem:\n[hass.hendrikthues.com] acme: error: 400 :: urn:ietf:params:acme:error:tls :: 81.169.145.70: remote error: tls: handshake failure\n" ACME CA="https://acme-v02.api.letsencrypt.org/directory" providerName=le.acme routerName=hass@docker rule="Host(`hass.hendrikthues.com`)"
whats could be the problem? Logic would suggest, i has to have something to do with Strato, since everything worked before.
Thanks, i tried it and we might be one step further got a different error now:
time="2024-06-05T11:52:28Z" level=error msg="Unable to obtain ACME certificate for domains \"hass.hendrikthues.com\": unable to generate a certificate for the domains [hass.hendrikthues.com]: error: one or more domains had a problem:\n[hass.hendrikthues.com] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: 2a01:238:20a:202:1070::: Invalid response from http://hass.hendrikthues.com/.well-known/acme-challenge/ZJDbOI6lwTzcpsHCT-H4d3cIZMtoMZa2x-SeS5NEt5Q: 404\n" providerName=le.acme ACME CA="https://acme-v02.api.letsencrypt.org/directory" routerName=hass@docker rule="Host(`hass.hendrikthues.com`)"
time="2024-06-05T11:52:31Z" level=error msg="Unable to obtain ACME certificate for domains \"immich.hendrikthues.com\": unable to generate a certificate for the domains [immich.hendrikthues.com]: error: one or more domains had a problem:\n[immich.hendrikthues.com] acme: error: 403 :: urn:ietf:params:acme:error:unauthorized :: 2a01:238:20a:202:1070::: Invalid response from http://immich.hendrikthues.com/.well-known/acme-challenge/HP8jbd3hzvn8ZBgsPpeXKNUIVh1l1L3Y5hweChxEydU: 404\n" routerName=immich@docker rule="Host(`immich.hendrikthues.com`)" providerName=le.acme ACME CA="https://acme-v02.api.letsencrypt.org/directory"
But where does this IP come from? Lets encrypt seems to be doing some magic and comes up with this IP to do some more magic. I have no idea, how to fix this.
i'm renting a server from them, already having a website under a different domain there.
I was testing some more. When i ping the main domain (hendrikthues.com), i get the correct IP. When i ping the sub domains, i get a different IP. So, i'm guessing, i'm using the Fritz Box DynDNS and/or Strato domains wrong...
because IPv6 doesn't do NAT ddns script on router publishes IP of router itself, and as it's ip for just router itself so it will just print routers web page and not send it to pi: likely need to run ipv6 ddns on pi itself
So, i fixed it. Although, it had nothing to do with what we discussed here.
In a nutshell: Every sub domain i have with strato needs to be updated with my current IP. Which means, i cannot use the DynDNS feature with my fritz box. I installed ddclient on my pi and configured it for every sub domain in intend to use. Now, traefik and letsencrypt are working just fine
Thanks for your help! You definitely pointed me in the right direction
