Good afternoon. I'm seeing the "timeout during connect" error, even when the nginx logs show the requests coming through with 200 response code.
192.168.7.131 - - [28/Sep/2021:16:02:59 -0500] "GET /.well-known/acme-challenge/5IIJtrS_wXk3gvExvbR1figrzLczY_6p0vx4I0fyRGc HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
192.168.7.131 - - [28/Sep/2021:16:02:59 -0500] "GET /.well-known/acme-challenge/a_PS8zY7YXTG2yYo7qLL1Ep-_HJRuyi-_mncx75c8qI HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
192.168.7.131 - - [28/Sep/2021:16:02:59 -0500] "GET /.well-known/acme-challenge/51QyxMK0pKrQwTnmQJ1KTLohuTLGq6A6pfTe5nhdPVU HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
192.168.7.131 - - [28/Sep/2021:16:02:59 -0500] "GET /.well-known/acme-challenge/NbrDuL4sZnNzBDk5ts4bYhGjKLh_5uBSeQL-lwpy-Ek HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
192.168.7.131 - - [28/Sep/2021:16:03:00 -0500] "GET /.well-known/acme-challenge/YhurVpbbyBm83ZuWzyaAn3gBPsxs1hNjgAPx7rK2fB0 HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)" "-"
I've validated that when I start up the nginx container, I can access these URLs externally using online services. I struggled with these errors intermittently last week into the weekend. It finally worked, and then today I tried to add another domain into the mix and it's happening again. Flipped over to the staging server because I re-ran things enough to get throttled. It's happening on both, staging and prod. Everything seems fine with external access (firewalls, routing, etc.) - just not sure what's going on exactly.
Note - sometimes I've observed nginx logs not showing successful requests for all 5 requests, sometimes it's only a few of the full set, the others don't come through at all. Sometimes the error from acme is also not "timeout" it's "connection reset by peer" ... it's not super consistent, tho (some of these were observed on the prod side, not the staging side, too).
My domain is: cusack-ruth.name auth.cusack-ruth.name weather.cusack-ruth.name automate.cusack-ruth.name frigate.cusack-ruth.name
I ran this command (via certbot Docker): Arguments: ['--webroot', '-w', '/var/www/certbot', '--staging', '--email', 'bdruth@gmail.com', '-d', 'cusack-ruth.name', '-d', 'auth.cusack-ruth.name', '-d', 'weather.cusack-ruth.name', '-d', 'automate.cusack-ruth.name', '-d', 'frigate.cusack-ruth.name', '--rsa-key-size', '4096', '--agree-tos', '--force-renewal']
It produced this output: During secondary validation: Fetching Timeout during connect (likely firewall problem)
where is each of the 5 verification URLs
My web server is (include version): nginx (via docker, latest)
The operating system my web server runs on is (include version): raspbian (buster)
My hosting provider, if applicable, is: n/a
or certbot-auto --version
if you're using Certbot): latest via docker (1.19.0)
